Question about HP Photosmart C6280 Printer
0xc19a0002 - HP Photosmart C6280 Printer
Posted by frank dadzie on
mohideen bava
    Scholar:
  • HP Expert
  • 199 Answers
Switch on your printer.
Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special Key Combo
Press and releasethe key in sequence 1, 2 and 3 buttons.
display says "support" R0631M
Press and release the right arrow button until the display says " System Configuration Menu".
OK button.
Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status
Press and release the OK button.
Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page..
Posted on Oct 16, 2013
0xc19a0002
1. connect the printer directly to the walloutlet...
2. then remove the ink cartridges and then clean the copper contacts with a lint free cloth... then put back the ink cartridges... and check
3. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec... then plug in the power chord at the back of the printer.. and check if that works...
4. if it does not work then unplug the power chord from the back of the printer... press and hold down the pound(#) and 6 key together... then plug in the power chord at the back of the printer... release the # and 6 key when the printer is powering back on... this is a reset which we are doing on the printer...
if the printer is on check if the error msg is there or not...
if it helps well and good.. however if it does not then try with a different set of ink cartridges... after changing the ink cartridges still it does not work then it might be an issue with the printer hardware...
Oct 17, 2013 | HP Photosmart C6180 All-In-One InkJet...
ERROR CODE 0xc19a0002
OK button.
Oct 11, 2013 | HP C6280 Photosmart All-in-One Printer...
0xC19A0002
Hi Sonfack,
Please follow this procedure and I hope this helps.
Error 0xc19a0002 on HP printers Solution:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
  10. If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jul 22, 2011 | HP Photosmart C6180 All-In-One InkJet...
ECHEC DU SYSTEME D ENCRE
Applicable error codes
This document applies to Ink System Failure error messages with any of the following codes:
0xC19A0001, 0xC19A0002, 0xC19A0003, 0xC19A0006, 0xC19A0008, 0xC19A0009, 0xC19A0013, 0xC19A0014, 0xC19A0015, 0xC19A0020, 0xC19A0021, 0xC19A0022, 0xC19A0023, 0xC19A0024, 0xC19A0025, 0xC19A0026, 0xC19A0027, 0xC19A0028, 0xC19A0030, 0xC19A0033, 0xC19A0034, 0xC19A0035, 0xC19A0036, 0xC19A0037, 0xc19A0040, 0xc19A0041, 0xc19A0042, 0xC19AC001, 0xC19AC002, 0xC19AC004, 0xC19AC008, 0xC19AC010, 0xC19AC020, 0xC19AC040, 0xC19AC063, 0xC19AC080, 0xC19AC0a5, 0xC19AC0c6, 0xC19AC0e7, 0xC19AC100, 0xC19AC129, 0xC19AC14a, 0xC19AC16b, 0xC19AC18c, 0xC19AC1ad, 0xC19AC1ce, 0xC19AC1ef, 0xC19AC200, 0xC19AC231, 0xC19AC252, 0xC19AC273, 0xC19AC294, 0xC19AC2b5, 0xC19AC2d6, 0xC19AC2f7, 0xC19AC318, 0xC19AC339, 0xC19AC35a, 0xC19AC37b, 0xC19AC39c, 0xC19AC3bd, 0xC19AC3de, 0xC19AC3ff, 0xC19AC400
HP Photosmart C6380 and others
Hi
There is to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
I took my scanner apart to clean the old ink and dust out of it. Over time the cartriges had weeped and it got real sticky. Now when puting it back together I have one piece that just does not seem to go...
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
Feb 21, 2010 | Office Equipment & Supplies
Ink failer
Hi
Feb 21, 2010 | HP Photosmart C6280 Printer
Hp 6380 error message 0xc19a0023
Hi
Feb 21, 2010 | HP Photosmart C6380 All-In-One InkJet...
0xc19a0035 error message
Hi
Feb 21, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart d7368
Here is the document that i want you to follow correctly inorder to solve your issue.
CLICK HERE TO VIEW==>> DOCUMENT
Please let me know the outcome after following the document.
Thank you so much.
adonscott
Jul 16, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6280 Printer Logo
192 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
