SOURCE: Foxconn P9657AB motherboard installation problem
You're Foxconn board uses the Award bios.
The long beeps you are hearing are telling you there is a problem with you're memory.
You're pic does not look like the Foxconn P9657AB-8EKRS2H MB as shown in the user manual. Found on This link.
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000297
The pic on Foxconn's site does but not the manual listed.
The motherboard uses four 240-pin slots with 1.8V for DDR2 memory only.
(Question? Did you're ECS MB use DDR2 memory)?
If you have more than 1 DIMM installed remove all but 1.
Move the DIMM into the closest slot next to the CPU.
Boot the PC & check for beeps. If still presant move the DIMM to the next slot & try again. Continue this through all four slots. Than try another DIMM. If the mother board continues to beep as mentioned than call Foxconn. (There is a bios update mentioned below for memory).
The CPU may come into question. (It’s revision). You may have to call Foxconn for this information. (580-272-0035). They do not place this information in their user manual. Most users have to call. The rev of the CPU may conflick with the memory causing you to receive the bios beeps. (I have had to return 2 boards for this reason). I picked an Asus board over Foxconn.
I have come across this with Foxconn motherboards these past two years. Suggest you update you’re bios. Foxconn has a revision dated, 3-28-2008 for memory before you call. After bios update test the memory again for beeps. Still there? Return the board is my suggestion.
It’s a guess that the red led will go away after the memory issue has been addressed. Normally there is a green led on most motherboards. This means standby. The board has power connected. I could not find any reference in the user manual * .pdf, for R450.
Good Luck ninjo61!
Mike
SOURCE: I have power but nothing else. Just the CPU fan and no boot.
try to check the power supply with suitable voltage....the important is the 4pin..it must connect or else the system will work but no display..in your case,i think the problem only is the voltage supply goes to the board...check my advice maybe it can help..
SOURCE: Sound cable connection
Look more closely at your motherboard, for a 4-pin "PC Speaker" label.
The "HD Audio" is _OUTPUT_ (left front, sub-woofer, right front, left back, right back) to Surround Sound speakers.
SOURCE: I have a FRU29R8260 motherboard where I need to
I am trying to get the manual on the foxconn site but they should be listed the owners manual. You use the jumpers in the case for the LEDS.
This is where i am trying to get the manual from http://www.foxconnsupport.com/download.aspx?models=en-us0000201&category=C000000001&series=en-us0000002&keywords=&sort=Motherboard%20Manual
