Question about Konica Minolta Office Equipment & Supplies
When i copy you can not see anything, it is completely black konika minolta d3510f
Posted by henry on
steven brickhouse
  • 19 Answers
Does the scanning light come on? if not it probably is the lamp or the starter unit that's attached to the lamp rail(the part that moves back and forth)
Posted on Oct 19, 2013
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
mochicas
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
SOURCE: C350 is printing is not clearly other color is over lap and shade
Clean the LED assy with the jig that you have inside the front cover.
Posted on Aug 23, 2009
Bizhubman
Ben
  • 108 Answers
SOURCE: Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
Posted on May 12, 2010
Black copy in konika minolta 215
reseat the image unit or have the image unit replaced normally done by replace the drum and developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 22, 2017 | Minolta Office Equipment & Supplies
I have a konika minolta bizhub c451, im trying to print but the image is coming out blank, how can i resolve this
Does the machine copy OK does the machine print out counter page and demo page ok?
Apr 12, 2016 | Minolta Office Equipment & Supplies
How to install Minolta dialta Di2510
Go to Konica Minolta Web site can use only windows 95 best is XP. If there is Windows 7 Go for it. This a legacy Minolta machine
Aug 24, 2014 | Konica Minolta di-2510 AFR-19 AFR19 ADF...
Konika minolta bizhub 350. When I try to Copy There is a message: "Pleaser Reposition Original". What does it mean? How can I fix it? The paper is checked (size).
BEFORE YOU PUT THE CHECK ON THE GLASS, SELECT THE PAPER DRAWER YOU WANT TO COPY ONTO, THEN PLACE THE CHECK ON THE GLASS, THE COPIER DOES NOT KNOW THAT SIZE
Aug 28, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
There is an error code c-2558 showing on my machine konica minolta bizhub c452 please do let me know the proper remedy for it ASAP
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Aug 21, 2011 | Konica Minolta bizhub C250 All-In-One...
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Jul 19, 2009 | Minolta magicolor 2400W Laser Printer
Jul 03, 2009 | Minolta C350 Printer
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
