Tv channels all ok, but all AV connections at back appear to have given up (hdmi and scart) Sound, but no picture, when consoles or dvd/vision box plugged in back and playing. Is it worth repairing??
SOURCE: no picture/sound on tv after connecting standard dvd player and inserting dvd
how many av inputs do you have on that tv? is it more than one? make sure you choose the right input. if that is not the problem then you are having a problem with av section in the tv I suggest that you take it to a repair man to get it fixed or you can use the RF cable to connect it to your tv. it is not the best but is saloution to the problem..good luck
SOURCE: tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
SOURCE: TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
SOURCE: cant tune tv in to use xbox 360
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
