This is about "configuring VPN". Want to configure Netopia R910 VPN over Dsl Modem to connect to our server(on domain) which is in canada without dialing VPN from India
Error code 651
This error corresponds to an error in a modem or any other connecting device
Try the folloging the instructions below:
If this is a dial-up connection, and you are using a supported external modem, turn off and then restart the modem. Close and restart Network and Dial-up Connections, and then redial. If the problem persists, try connecting at a lower initial speed. See To change the maximum modem port speed. Make sure you correctly configured your modem for remote access. To check your configuration, see To configure a connection. If this is a virtual private network (VPN) connection, you might have specified an incorrect TCP/IP address in the connection configuration, or the server that you are trying to reach might not be available. To determine if the server is available, see your system administrator.
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
What OS are you running on your pc?
What VPN client are you using on your pc?
Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Theres alot of differnet things i could ask you, but im going to assume you're jsut setting up a basic VPN. That means that somebody is telecommuting to work and wants to hit the server at work.
That means you have a static ip at work, and your at home workers has whatever, a internet connection lets say. Im thinking DSL with ATT since its a netopia 3347N.
If the netopia has a gui interface, you cant vpn thru it. Its not a VPN router. Its a residential router that you're trying to make do too much.
The sad news is, you can't upgrade it to an Enterprise having firmware router anymore, netopia use to offer that, but when Motorolla bought them out last year, they did away with that nice little feature. For true VPN'ing with a router, first, go get a VPN router to start with.
Most people accomplish what you are doing by putting the netopia in to bridegemode, and then putting a VPN router like a linksys behind it.
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
If this is a DSL Gateway Router, check the settings on the modem and make sure that the DHCP server is enabled.
it woould be of great help if you could provide the exact model number of the Netopia modem so that I could check if there is configuration page which you can access and check the settings..
