2001 Mercedes-Benz CLK-Class Logo
Posted on Apr 22, 2009
Need mercedes radio code
I just purchashed a 2001 clk 55 amg and need the radio code. serial number al1910yo337749. can u please help thank you
  • Marvin
    Marvin May 11, 2010
    the dealer can provide that code, we have no access to these radio anti-theft codes, they are security codes to discourage theft, wouldn't work very well if they where easy to get on the internet, there is a pay sit that may be able to help for a fee. radio_code.com
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
7673
Points
21
Have you asked the dealer ship if you are in the uk it will cost about £20
Reset code for radio 2001 mercedes benz 430 clk
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing.
This information canthen be used to see if a code can be calculated
Try to replace oil but could not find a oil plug where is oil plug of CLK55 AMG
IF your car CLK 55 AMG it's better to get your car in to the dealer for service because it's need much knowledge to replace oil in this particular car, and must get the right oil for it, it's very particular oil need to fill in to the engine, must use Mobil 0W-40 fully synthetic oil and also need to drain oil from oil cooler and need to **** oil in side the filter housing, drain plug is under oil pan. my advice is get in to the dealer, it's up to you. is this information helped you?
8helpful
3answers
Mercedes Benz CLK 320 1998 Radio Code
try asking here
www.ukbookshelf.co.uk
I have a 2000 clk 55 amg battery is dead cant open trunk with either key and i need to jump start it or change the battery
Use emergency key inside remote,move clip on top of remote to remove blade
Insert in lock above rear no plate
1helpful
Need a radio code for a mercedes benz clk 430 2001 coupe
You can get the code from any Mercedes dealer around you. Or you can have the code by taking the radio out and take the serial to a radio repair shop and they can get the code from the serial.
Its a efurbished radio
Okay, your dealer or the person who sold the car to you should give you that information or be able to get it for you. If not, get the serial number for your radio (on the back of the radio) and your VIN (Vehicle Identification Number) , write them down and post your request on this forum: http://www.benzworld.org/forums/audio-telematics-forum/1254230-need-radio-code-4.html
Got a 2001 clk 55 amg and the stock alarm keeps going off for no reason
have vehicle scanned for codes it is the only sure fire way to solve or diagnose this issue.
2helpful
Need Radio Code for ML320 Mercedes Benz
The main dealer will supply the code usually for a small charge.
Have a look on line first though because some are offered freely .
You will need the model year and chassis number.
1helpful
2answers
4helpful
2answers
Need Radio Code for CLK430 Mercedes Benz
Yes. Every time you disconnect the batterie you need to put radio code again.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
