Question about Denon AVR 1312
There is a common problem with a zener diode in that amp that goes bad. ZD3 is a 18v zener and it goes short. Sometimes R9 on the back will open when this happens. Need to have them replaced.
Posted on Oct 09, 2013
Steve, I've been trying to solve the same problem, i have a BA subwoofer on my Denon AVR 1312, fuse on subwoofer is good. Can you explain more about this ZD3 Zener diode - is this in the subwoofer, the receiver - what must I do to fix this?
ZD3 is in the subwoofer. If it is shorted, it needs to be replaced.
SOURCE: Denon avr-485 wont turn on at all. The unit won't
Check power cord connection.
Posted on Nov 23, 2009
SOURCE: denon avr-790 sirius antenna antenna connection
The connection is similar to what is mentioned in the user manual bellow. Slightly different model but the connections are universally similar:
http://www.rotel.com/content/manuals_archived/rb850.pdf
Thank You
Posted on Oct 31, 2010
SOURCE: connect wii to Avr 1312 Denon
What you would have to do is connect the video output of the wii directly to the video input of the bug projector. Also connect the audio cables to it as well. Then connect an audio cable to the projector's audio out or otherwise labeled as "variable out" then connect the other end of that to the matching input terminal, found often labeled as "audio in" on the receiver's grouping of input selections for TV.
Then, on the projector, select the video mode you connected the wii cables to.
Posted on Jun 19, 2012
SOURCE: NO SOUND FROM 6 MONTH SHARP AQUOS 60" LCD CONNECTED TO DENON AVR 1312
Check to make sure that when you are on that input that HDMI shows up in the front display. If it does not, then you need to turnit on. If it still does not, you could have a problem with your HDMI board on your receiver not recognising the signal.
Posted on Jul 03, 2012
Sep 25, 2014 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Jul 31, 2014 | Denon AVR1312 51 Channels Receiver
Feb 27, 2014 | Denon AVR 1312
Nov 30, 2013 | Mitsubishi HC3000U Multimedia Projector
Mar 22, 2013 | Denon AVR-1513
Jan 09, 2013 | Denon AVR 1312
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
Jul 03, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
Jun 18, 2012 | Denon AVR 1312
Feb 17, 2014 | Denon AVR 1312
273 people viewed this question
