Question about LG 42PC3D 42 in. Plasma Television
My lg tv/monitor dm2352 has tiny black dots like the distance between the pixels is visible when the image is bright. Should I RTM?
2 Related Answers
Anonymous
SOURCE: I have a LG plasma 42PC1D (4 years old). For the
I have the same model and went to the www.lge.com support site and did a "chat" explained the same issue as you ... in dark areas, there are many red pixels ... 2 days later an LG tech came to the house and told me that is the result of multiple dead pixels and a "misfire" in the chip board. He said that LG had a zero tolerance policy and he would replace all parts inside or replace the TV if parts are not available. Very nice gentlemen and very nice chat support. I would do the same if I were you, which is exactly what I did.
Posted on Feb 08, 2010
Anonymous
SOURCE: LG plasma tv mofel #42pc3d...when there is a dark
i would say try the ysus board ot the control board this usally cures it
Posted on May 19, 2010
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
I have a green dot on my screen of my JVC HD52G887
Hello. If it resembles a tiny bright green dot, this is most probably a dead pixel. In the troubleshooting guide in the user manual, the manufacturer states that some pixel loss is normal--either they will be gone or permanently "on". If the unit is new(i.e. still under some warranty) talk with the supplier about options--they *may* decide to replace it if the dot is in a particularly annoying location. Be aware though, they won't be under obligation to do so. I own a LCD projector with a few visible pixels--as devices such as these(lcd tv's, projectors, plasma, etc.) age, this type of phenomenon is going to occur. Normally--and this certainly isn't always true, there is a tolerance of 3-9 pixels. Check with the supplier and/or manufacturer for individual specs. Especially if the unit is under warranty!--Hope I successfully assisted you.---Rick
Jun 24, 2009 | JVC TS-CL110UAA Projector Lamp
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
May 03, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
Contrast ratio of tft monitors
Contrast ratio is the ratio between black and white. So low contrast ratio (5000:1) means you can;t see the screen so well in a bright room (where there's a lot of sunlight) A higher contrast ratio (20000:1) means the screen is brighter so easier to see in bright rooms.
Pixel pitch refers to the distance between pixels. The lower the pixel pitch, the sharper the image
Feb 04, 2008 | Audio Players & Recorders
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Menu and select OK to activate it. Once Pixel Mapping is completed the Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's Mode Menu and select OK to activate it. Once Pixel Mapping is completed the Mode Menu displays. The bright dot should no longer appear in your downloaded images.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Small bright dot
Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Pixel Mapping is a feature of the camera to check and adjust the CCD and image processing functions. Locate Pixel Mapping in the camera's menu and select OK to activate it. Once Pixel Mapping is completed the Menu displays. The bright dot should no longer appear in your downloaded images.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Small bright dot
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Small bright dot
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
LG 42PC3D 42 in. Plasma Television Logo
50 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
