Question about Summit SPWD1800 Laundry : Washer/Dryer Combos
Spwd1800 not drying - Summit SPWD1800 Laundry : Washer/Dryer Combos
I have a 1992 jeep Cherokee Laredo 4.0 L6. How do I fix dry starting?
dry, i love new terms for problems my first like this.
  1. dry road.
  2. no beer in hand.
  3. fuel tank dry (buy some, LOL)
  4. coolant dry starts. (testing new engines....)
or what, do add a noun to the dry work,
what is dry?
and what fluid ends the dry.?
Nov 04, 2015 | Jeep Cars & Trucks
What is the error 1 sign for my summit spwd 1800
It means something is wrong with door lock mechanism.im currently having same problem.
Jul 05, 2014 | Summit SPWD1800
My summit spwd1800 gives me error code 1 can not look door, how can i fix this?
your locking clamps on the door and door well are probably out of alignment a switch censer in side is out of place so my best bet is to take it to a repairer
Jul 03, 2014 | Washing Machines
Dryer proplem
Rather than try to give you answers, I'm giving you this online link that COULD lead you to a solution: http://appliantology.org/topic/42011-washer-dryer-combo-error-code-er13-haier-summit-ariston/
I looked at it for a few minutes and answers are up and down between encouragement and discouragement. One suggestion is a bad thermostat at the top of the unit, but I'm not sure if you'll be successful in locating replacement parts according to some of the things I glanced at. Hope this helps.
Jun 28, 2014 | Summit SPWD1800 24" Washer/Dryer Combo...
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
What is the best setting to dry jeans on a kenmore 9000 electric
Use Auto Dry for most things and vary the "dryness" level to more or less depending on the thickness of the material you are drying. Auto is most efficient and will adjust itself for finish time.
Auto dry and select "more dry" before hitting start, for jeans or towels.
Aug 28, 2009 | Kenmore Dryers
Summit SPWD1800 Laundry : Washer/Dryer Combos Logo
212 people viewed this question
Top Summit Washing Machines Experts
ray gallant
Dai Boyce
Dai Boyce
 Russ Hill
Russ Hill
Are you a Summit Washing Machine Expert? Answer questions, earn points and help others
