Question about ASUS P5G41-M Motherboard S775 Intel G41 mATX SATA Gigabit LAN (90-MIBAA0-G0EAY0KZ)
Having VERY MUCH experience," how to install new O.S.(xp / WIN7) in pc". I have done it many time before now,but i am facing one problem now. PROBLEM is "my pc Shut Off Automatically after few min.,when pc is booting from O.S. CD(XP,WIN7, VISTA all tried) " I have NEW Asus G41 mother board,Intel Dual Core processor ,SATA- LG DVD writer,17"Samsung monitor, iball--keyboard,mouse,UPS,spike guard, umax-smps, 2g Transcend ram ,160 gb hitachi hard disk-SATA, i have checked that, all components work properly if tested individually. at start up ,NUM LOCK LED glows, then LEDs OF DVD,POW.HARD DISK glow. i have also tested hard-disk & LG DVD(on other PC) it also work fine,,FAN of SMPS moves,, LED on MOTHER BOARD also glows, my PC's turn off automatically even if i am present in BOOT SCREEN OPTION is it 'motherboard problem' ??
1 Related Answer
Tapas Basu
  • 80 Answers
SOURCE: My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
Posted on Nov 30, 2011
5helpful
3answers
1helpful
Received a reply from "Geekman"
Your desktop was designed for Win7 and WILL NOT work properly on XP. You can however, install the support for XP part of Win7 Ultimate Edition. Aparently it works realy well but I have no personal dealings with that side as I like Win7.
Hope that brings an end to your XP torment.
The card was working fine in windows xp. But i recently installed windows 7 and the card is not detected.
need a new driver for Win7 for the SB card....for Win7 HW mafgs have not develoepd any drivers as the Win7 source code was not provided to the Hw nfgs by MS....
MS has develoepd std drivers for all HWs that can install any HWs....
you need to register with MS your copy of Win7 and download all updates and the SB card will auto install once all updates are done....
I have replaced my XP Computer for a Windows 7 and downloaded the software for my JVC Everio HDD Camcorder GZ-MG36EKM.However a message onscreen says that the camcorder software is incompatible with my new...
If your Windows7 work in x64 operating system, of course it would be incompatibility if you use driver for XP in it, since Windows XP use x32 system, that's where the problem come from (I've faced the same problem sooo many times for several software) . You need to check your OS first (push Windows and Pause Break button together to see it) and make sure which one is your OS, 32 or 64 bit OS? If you have 64 bit OS, for any software that you want to download from internet, you must choose that support 64 bit OS. Some of x32 software still installable in Win7 64 bit, but yes, other software need us to spend some bucks to download them.
If you upgrade your Windows7 you may use XP Mode that allow you to install XP driver or software in Win7 based PC, but once again, ITS NOT FREE !!
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 • Cameras
1helpful
Can you give me a link to download a driver for Protax DC500t camera that works on windows7? The disk I have only works on windows xp Thanks, Peter
If your Windows7 is x32 version, then your driver should work in it. But if you have x64 version, you'll get some trouble to install driver for XP in Win7 PCs. I've stuck the same problem like you, but my case was modem problem. Programs like game or other application that can be installed in XP usually can be installed in Win7 64 bit and extracted in Program Files (x86), but driver case is an exception.
I've search via google but I got nothing. Actually, there is a way to install XP driver in Win7 which is use XP Mode in Win7, but you must upgrade your OS to Win7 Ultimate (I think, see microsoft website to make sure) so you can use this mode.
or
you can install two OS in your PC, Win7 and Win XP maybe. When you want to install driver for XP or if you want to do some work related to this driver, you can start up with XP OS, but if you want to do other work, use Win7.
This is so unconvenient, but better than you can't connect your camera to your PC.
Good luck Peter !
Hope this help and be kind to rate my answer please.
(^_^)
Jan 06, 2011 • Cameras
I have a CanoScan LiDE80 that wont work now with my new operating system, Windows 7...when trying to install it.. says I need drivers but can't find compatiable one??? Any suggestions as I love this...
Do you have Win7 32-bit or 64-bit? If you have the 32-bit, the driver you need is here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide_80#DriversAndSoftware . This driver works for Win2K-Win7. This is an unsigned driver and probably will not work in Win7 64-bit.
In my experience, Canon is very poor at supporting their scanners for 64-bit OS versions. In fact, they do not have a Vista 64-bit compatible version of the drivers for this scanner.
The only solutions I have found are tedious. 1) Keep your old computer that works with the scanner and transfer files on a USB drive or optical disc (RW is better for this). 2) Set up a virtual computer with an OS that works with the scanner. If you have Win7 Pro or Ultimate, you can do this for free. Download Microsoft's Virtual PC and the XP mode package. Install both in order. For other versions of Win7, you will need a virtualization program (Parallels, Virtual PC, VMWare) and a licensed version of XP (or other OS that will work with the scanner). Set up the virtual computer program and install the OS.
Next install your scanner to the virtual computer and use it in that "machine". You may need to transfer files to external or optical media to share the documents. You can't install a printer on both the virtual computer and the real computer at the same time (at least with XP mode).
I hope this helps.
(I tried using the compatibility mode and accepting the unsigned driver for a Win7 Home Premium 64-bit machine for a different Canon scanner. It didn't work and I have dealt with a number of old hardware and new OS issues over time.)
I have a hp pavilion 2120tx with windows 7 and i want to dual boot windows 7 and windows xp [windows 7 first]
You can create a Dual Boot in ur machine....
C: XP
D: or E: or F: as Win7
You need to re-format your disk, back up all critical data in your disk....
once done...boot with XP disk in CD drive....
after format, create multiple partitions....C: , D: , E: etc as per your preference
install XP in C:
once done...start PC and let the machine boot from C: XP...once you get Desktop in XP
install Win7 in D: or E: as prefered....once done..
in the startup screen you will get these 2 options
1 load earlier version of Windows
2 Windows 7
to make Win7 as default, right click on My computer (Win7), Properties / Advancd System Settings / Advanced Tab / Startup and Recovery / Under System Startup - Chose the Default OS by the down arrow and the time to it must be displayed in the startup to chose the OS....by this method you can chose Win7 or Xp to load...make your choice as prefered...
reg
for more info on formating and loading OS visit my site
www.sureshayyar.110mb.com
Windows 7 conversion windows xp soft wear
I assume you want to go from XP to Win7 which is not supported by Microsoft.
Laplink make an excellent and cheap product called pcmover Upgrade Assistant which does the job brilliantly on either the same PC or moving to another and upgrading to Win7.
http://www.laplink.com/pcmover/
You install it on the XP system and save a small file it generates. Then install Win7 as a custom install (without formatting) and re-install pcmover. Select the file you saved and a couple of minutes later pretty much everything is back under the new system ( afew things may need redoing like some drivers, AV software etc. but it's minimal)
Have used this on a number of conversions from XP and Vista to Win7 and it works great.
I HAVE A \LEXMARK X2330 INSTALLED ON AN xp PC. I
I am assuming that the Win7 can "see" the Lexmark on the XP machine but not print.
OK, on the Win7 laptop in question:
Click Control Panel > Printers > Add Local Printer
Create New Port = Local Port
Port name is \\yourXPcomputername\Printername
Now Win7 will install a print driver to work with the shared Lexmark printer.
ASUS P5G41-M Motherboard S775 Intel G41 mATX SATA Gigabit LAN (90-MIBAA0-G0EAY0KZ) Logo
Top ASUS Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
