SOURCE: Intermittent control panel issues
hi
the dryer works with the voltage of 250v 60z . u need multimeter or voltmeter to trouble shoot..
This switch, located on the control panel, is usually the push-button type. Start switches don't fail often, but it does happen. To check the start switch, remove the control panel and test the switch with a VOM set to the RX1 scale. Disconnect the leads from the switch terminals and clip one VOM probe to each terminal. Press the switch button. If the meter reads zero, the switch is working. If the needle jumps to a high reading, the switch is faulty and should be replaced. Replace the switch with a new one of the same type, connecting the new switch the same way the old one was connected.
thank u .. if any post me.
SOURCE: Control Panel turns off
I have a GE DCV515EF0WW front-load dryer. When the dryer is on there is a scratching noise that seems to come from the front edge of the drum. The unit just started doing this. I checked around the drum for debris. I found some lint and cleaned it as best asI could. Any suggestions. The unit is heating properly or so it seems. Thanks in advance.
SOURCE: My dryer ran fine with my last load of only 3
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Hi
The F22 stands for the CCU/Touch pad error. In
other words, the keypad has lost connection with the control board behind it.
Follow the steps:-
unplug the washer
take off the console
check the connection between the touch pad and the CCU board
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
