Question about Ranger RCI-2995DX Base Scanner
Ground wire Should I put a ground wire on the chassis of my radio?
Posted by Sherman Thames on
B_a_Geek
    Sergeant:
  • 396 Answers
Please Re-post in the correct forum. This is for cell phones.
Posted on Oct 19, 2013
I need to know whiCh are the power and ground wires coming out from a 2011 cobra 29lxI dont have the output plug so i want to solder my own power pluds to come out of the radio
Open the radio up. Follow the wires from the plug and one will terminate to ground. Most likely on a board, where you may have to trace that wire to the chassis, which is ground. Most likely, they are color coded. Black is ground, red is power.
Apr 10, 2017 | Cobra Radio Communications
Ground wire location
You can connect the ground wire to any part of the chassis.
As for the orange/illumination wire... depends on the year of your truck and the make/model of the new radio. Re-check the installation instructions - it should tell you where to connect it.
Feb 09, 2014 | Mitsubishi Montero Sport Cars & Trucks
How to install a aftermarket radio in a 99 eclipse rs
Run a ground from the radio chassis ground to a grounding point on the car. Some radios ground through the chassis and not the harness.
Nov 11, 2013 | Pioneer Car Audio & Video
I need wiring diagram from factory radio bougt car at sale old radio removed putting in pioneer stero on 1993 nissian maxima
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Yellow
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
pls rate because noone has been rating hope this helps
Jul 10, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Radio and inside lights not working
Check your grounding, prob have used illumination line as ground, when lights switched on it goes to 12 volts and if connected to radio ground fuse will pop. Ground radio to chassis and isolate the wire you have used, replace fuse (probably blown) and should fix your problem.
May 25, 2010 | 1990 Nissan 300ZX
Jeep radio w/cd player
begin with the easy one. code is for battery disconnect.(if you had the battery disconnected while installing that will explain it) if you ground the antenna wire to the chassis does it still spark? Is it a power antenna? I'd make sure that somehow the clock and radio wiring is not reversed and that the radio is well grounded (you can add a ground from the case to the main dash rail if you need to. As with any used item, there is a possibility also that there is just something wrong with the radio, but I don't think that yet!
Feb 13, 2010 | 1994 Jeep Grand Cherokee
What is source ground on an equalizer
Ground Source, not the other way around. It is a metallic place, interconnected to the vehicle chassis, where the electricity will flow from positive to negative. Best bet is to connect your equalizer black ground wire to the radio black ground wire, since it has already been bolted to a good ground. Furthermore, grounding it to radio, will prevent any humming between the two units.
Jan 22, 2010 | Boss AVA-1204 7-Band Car Equalizer
DNX 7100
What type of car is it? Make sure the Black (Ground) lead for the radio is connected to an adequate ground wire in the harness or to chassis metal. Some vehicles (Nissan, Mitsubishi) have no ground lead in their harnesses and need to be grounded to bare metal.
Aug 17, 2008 | Kenwood DNX7100 Car Video Player
Road king micophone
Most standard CB microphones are 4 wires:
Audio IN (from Mic)
Speaker
PTT (TX)
Ground.
To determine which is which on the radio side:
a. the Audio IN (from Mic) would read a high resistance to ground (chassis) of CB radio;
b. the Speaker when connected to the ground would activate the receive speaker. To verify, power up the radio, squelch all the way down, when shorted to ground, speaker will produce background noise/sound;
c. when PTT (TX) is shorted to the ground, the rig will transmit and the red TX indicator will light up;
d. Ground. when tested with an Ohmmeter to the chassis will read 0 ohms.
Hope this be of some help/idea. Pls post back how things turn up or should you need additional information.
Good luck and kind regards.
Nov 12, 2007 | Cherokee CBS2100 40-Channels Base CB Radio
Ranger RCI-2995DX Base Scanner Logo
82 people viewed this question
Top Ranger Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
