In group of 120 grade 11 learners each takes at least one of the following 3 subjects 13 learners take all three subjects 13 took all three 31 take maths and science 23 take maths and accounting 16 take science accounting 35 take maths only 22 take only science 19 take accounting) answer draw in a venn diagram
Connect the cable from the dish to the LNB-IN port and switch the OVHD decoder ON. The decoder will pick up the OVHD signal automatically. The decoder must be activated using the cellphone by entering *120*6843*1# and then follow the menu. https://www.spacetv.co.za/wp-content/uploads/2018/11/openview-brochure.pdf
Why do you need such a speech? And where could we find "a grade 4 learner no longer than two minutes?" I thought length of "learners" would be expressed in feet and inches, or their metric equivalents, but not in units of time!
Do you want combinations or permutations? They're different things. A combination of n items taken m at a time, sometimes written "nCm", selects m items from a group of n without regard to order. A permutation of n items taken m at a time, sometimes written "nPm", selects m items from a group of m with regard to order.
Given six numbers, there are six combinations of one number, 15 combinations of two numbers, 20 combinations of three numbers, 15 combinations of four numbers, six combinations of five numbers, and one combination of six numbers.
Given six numbers, there are six permutations of one number, 30 permutations of two numbers, 120 permutations of three numbers, 360 permutations of four numbers, 720 permutations of five numbers, and 720 permutations of six numbers.
The procedure for tightening the head screws is critical.
Start with bolt numbered one which for the front cylinder is the left side or spark plug side rear bolt then the left side or spark plug side front bolt which is the number 2 bolt then the rear right side bolt which is the number three bolt and then the front right side bolt which is the number four bolt AND tighten the head bolts in sequence from one to four in the following steps:
Tighten each bolt to 96-120 in-lbs, then tighten each bolt to 13-15 ft-lbs, then loosen all bolts, then tighten three stages to: first stage tighten each bolt to 96-120 in-lbs; second stage tighten each bolt to 13-15 ft-lbs. THEN mark each cylinder head and head bolt shoulder with a reference line and tighten each bolt an additional 85-95 degrees.
Start with bolt numbered one which for the rear cylinder is the left side or spark plug side front bolt then the left side or spark plug side rear bolt is number two then the front right side bolt is number three and then the rear right side bolt is number four AND tighten the head bolts in sequence from one to four in the above steps.
96-120 in-lbs = (11-14 newton meters)
13-15 ft-lbs = (18-20 newton meters)
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
I hope that was helpful to you, good luck and take care.
In general, storage capacity depends on which image size and quality you have selected.
For your information, here is the number of images recordable in a 256MB Compact Flash in the respective image size and quality. Since the image size may vary depending on scenes and subjects, these are approximate values only.
Image size 3264x2448 / 3264x2176 / 2560x1920 / 2080x1560 /1600x1200 / 640x480
Std: 106 / 118 / 167 / 243 / 381 / 1043
FINE: 61 / 69 / 99 / 146 / 235 / 781
X.FIN: 31 / 35 / 50 / 75 / 124 / 594
TIFF: 10 / 11 / 17 / 25 / 43 / 245
RAW and JPEG: 15 / 16 / 17 / 18 / 19 / 20
RAW: 21
Movie :
Image size 544x408 / 320x240
Movie(15fps) : 7 min. 9 sec / 13 min. 44 sec
Movie(30fps) : 4 min. 15 sec / 7 min. 3 sec
