SOURCE: I dropped my Samsung LN-T4053H 40 in. LCD
yes. sorry to deliver bad news. cost to repair is 90% the cost of when you purchased. panel is around 400-500 plus your labor. samsung may have flat rate program but still is not very economical. sorry again.
SOURCE: Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
SOURCE: I have a permanent dark/black 4.5" wide vertical
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
SOURCE: 1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
Hey Carson,
Without seeing the set, it is hard to pin down the problem. But I would guess you have a problem with either the t-con board, t-con ribbon connection problem, or a failing LCD panel. Samsungs are known for premature panel failures. The problem is by that time you pay a diagnosis fee, parts and labor, you would be close to the price of a new set. If you are financially able to buy another set, I would do so and toss your old one on Craigslist. If you get $40 bucks for it take the money and run !!!
