Question about Lenovo G550-29583AU Notebook
How to use the touchpad of lenovo g500 to function for scrolll bar
Peter Schieszl
    New Friend:
Hey,
Did you manage to solve the problem? I've got my g500 too, and cannot scroll with the touchpad...
Can you help me?
Posted on Mar 23, 2014
My lenovo G500 wont turn on
Those units have a special reset procedure when this happens. The keys to hit are in the manual. Check it out
Aug 12, 2015 | Lenovo Essential G500 Laptop Computer -...
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
Jul 20, 2015 | Lenovo Computers & Internet
Please help me : :' my pc is lenovo g500 and i forgot password bios who help me please
I do google your problem and look to the lenovo G500 manual.
here's the manual says.
sources: http://www.lenovo.com/shop/americas/content/user_guides/g410_g510_ug_en.pdf
BIOS password problems I forgot my password. • If you forget your user password, you must ask the system administrator to reset your user password. • If you forget your HDD password, a Lenovo authorized servicer cannot reset your password or recover data from the hard disk. You must take your computer to a Lenovo authorized servicer or a marketing representative to have the hard disk drive replaced. Proof of purchase is required, and a fee will be charged for parts and service. • If you forget your administrator password, a Lenovo authorized servicer cannot reset your password. You must take your computer to a Lenovo authorized servicer or a marketing representative to have the system board replaced. Proof of purchase is required, and a fee will be charged for parts and service.
But in my own way of troubleshooting.
1. open your Lenovo G500
2. Check your motherboard and look for bios/cmos battery.
3. Remove the battery
4. Get flat screw driver then put it between two pins where the cmos battery attached.
5. Hold it for 10 to 15 sec.
6. Put the cmos battery back and the motherboard
7. Power it up and holla the bios setting has been reset to default.
Here the sample image of Lenovo G500 motherboard
Jun 11, 2015 | Lenovo Computers & Internet
Safe mode in lennovo g500
When you start your computer. Hit the F8 key, and then a prompt will come up to boot in Safe Mode, Safe Mode with Networking, and Safe Mode in Command Prompt. Make your choice.
Apr 08, 2014 | Lenovo Essential G500 Laptop Computer -...
Lenovo g500 restarting itself
There is a variable (system setting) integrated into the Windows Update tab in the control panel that enables and disables notifications of automatic restart to complete the installation of system updates.
Nov 13, 2013 | Lenovo Computers & Internet
Keyboard unlock
Like most modern laptops, IBM/Lenovo laptops feature a built-in touchpad that you can use as a substitute for an external mouse device. If you experience a non-functional or "locked" touchpad, then you have one of two possible problems; either the touchpad's drivers are corrupt or a user has manually locked the touchpad. In either case, you can unlock your touchpad and restore it to functionality quickly.
Open your web browser and paste the following URL in the address bar:
Click the "Download" button and then click "I agree" to save the Lenovo touchpad driver installation file to your computer. Double-click the EXE file that you downloaded. Doing so opens the driver's installation wizard. Follow the on-screen prompts to re-install your Lenovo's touchpad drivers. If your locked touchpad is due to a corrupt or outdated device driver, then your touchpad is now unlocked and functional. Activate Touchpad Hold the Windows logo key and press the R key to open a run command box. Type "control mouse" in the box and press Enter. The Mouse Properties control panel window opens. Click the "Device Settings" tab. Click the Lenovo Touchpad in the "Devices" list and click the "Enable" button to activate the Touchpad. Click the "OK" button to save your changes. Your Lenovo's touchpad is unlocked and ready for use. Lenovo support
http://consumersupport.lenovo.com/vn/en/DriversDownLoads/drivers_show_120.html
Feb 24, 2013 | Lenovo Computers & Internet
How to change touchpad settings for lenovo g550, I hate this touchpad, please help
You really can't do much with settings for a touchpad. I would recommend disabling it and using a wireless mouse. var fctb_tool=null; function FCTB_Init_c6f64f985d3644929e3995eea1c55206(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d35d1f3861484992b99b0e9345d90151(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Lenovo G550-29583AU Notebook
How do I turn of the mousepad on my lenovo 3000 N200 laptop? I am using a remote mouse & sometimes the pointer jumps to a different location. Turning off the mousepad may help?
If there isn't a button directly over your touchpad for turning the pad off\on, then there should be a function key for doing this. Typically, you will have to press the Function key, usually located near the space bar, and press one of the "F" keys at the same time. Look for one of the F1 - F12 keys to have a symbol for the touchpad or mouse. That's usually the one that will turn off the touchpad.
Aug 04, 2010 | Lenovo 3000 N200 Notebook
Compaq presario r3000 touchpad scroll function not working after allowing remote access to a telecoms analyst to correct a broadband problem. I have reloaded the ALPS touchpad driver from HP. Still no...
My R3000 touchpad would not scrolll or allow double-tap. I downloaded the synaptics driver, not the ALPS driver on Compaq's site, and it works perfectly now.
Feb 12, 2010 | Compaq Presario R3000 Notebook
Touchpad tapping is not working
You need to download and re-install touchpad drivers to get the tapping function working.
You can download the touchpad drivers from the link below:
http://blogntech.com/download-lenovo-ideapad-s10-xp-driver.html
May 09, 2009 | Lenovo IdeaPad S10-1208U Netbook
Lenovo G550-29583AU Notebook Logo
512 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
