Question about Konica Minolta Bizhub C550
Unable to enter low power mode - Konica Minolta Bizhub C550
Unable to enter sp mode for ricoh mp4500 machine
The proceedure is to press the following buttons in this order; clear modes, 1,0,7,clear. hold clear button for at least 5 seconds. This should get you in.
Mar 27, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Machine error 28
Well it's a low temp error for the fusing assembly. Sounds like you already had it in Maintenance Mode. Sometimes those errors can only be cleared out by entering maintenance mode and pressing 9,9 to exit out. Should then start the normal warm up procedure. If the problem continues then reseat the fuser or take it out and measure for continuity across the lamp and thermostat. The service manual also recommends checking the line voltage. Basically make sure it's plugged straight into a wall outlet and no other large power sources on the same circuit. Example, another copier or this time of the year a small space heater.
Maintenance Mode enterance Press Menu/Set and Black start button and Up arrow 4 times. Machine will read Maintenance on the display if done correctly. Press 9,9 to exit of the mode and the machine will attempt to restart normally.
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 11, 2014 | Brother MFC-9420CN All-In-One Laser...
Panasonic in lock mode and unable to unlock picture
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip. If you can't succeed, you must enter its service mode menu to make an unlock. Visit the site named 'Electro-help'. Click this link. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
Dec 18, 2012 | Panasonic CT-32E13 32" TV
HP T1100 paper load incorrect
Check:
1. Was its sensing the paper while loading the media?(roll or sheet)
2. Perform 'service test for sensors' to know how media sensor is working.. if its fails clean media sensor located left side of carriage assembly. If the media sensor becomes dirty due to ink, printer unable to detects the medias edge. Clean sensor gently.
Entering in service mode: Power off the printer using from the operational panel off button. Press & hold up arrow,ok button switch on the printer, wait few seconds to enter in service mode, once its enters in service mode, scroll to sensor test.
Nov 28, 2012 | HP Designjet T1100ps Printer
Computer Gateway SX2802-07 PC Desktop keeps entering power save mode
could be power mode is not set correctly. could be clock/battery is low and causing early saver mode? is your pc time/date correct?
is your ac adapter working properly or is it going bad?
Aug 24, 2012 | Gateway SX2802-07 PC Desktop
When i open my laptop one message shows the path is not correct.After showing the welcome it will be balank. i am unable to enter the main screen.
are u able to boot in safe mode?------>on power on keep tapping F8 key.u can select safe mode and press enter->login to adminsitrator mode(password can be blank).if u are able to login to safe mode then itz an issue with ur OS(win xp or win vista or win7 whichever is installed on ur pc).If u are unable to login to safe mode please let me know
Sep 20, 2010 | Computers & Internet
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
Program copier not to sleep at work
  1. Press the [Access A] (key symbol) button on the top, right corner of the Control Panel.
  2. Enter the system password using the numeric keypad, then select [Enter] on the Touch Screen. The default password is 1111.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button and re-enter the password. To cancel the operation, select [Cancel]. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
  3. If the Internal Auditron is not enabled, select the [Go To Tools] button (does not apply to copier-only models). If the Internal Auditron is enabled, select the [Tools Pathway] button.
  4. Select the [More] button.
  5. Select the [Power Saver Administration] button.
  6. Select the [Set Duration Times] button.
  7. To adjust the 'From Standby Mode to Low Power Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Standby to Low Power may be set between 1 - 120 minutes.
  8. To adjust the 'From Low Power Mode to Sleep Mode' time-out, select that box so it turns black then enter a new time using the numeric keypad on the Control Panel. The Low Power to Sleep may be set between 0 - 120 minutes.
    NOTE: There should be a minimum of one minute between the 'From Standby Mode to Low Power Mode' and 'From Low Power Mode to Sleep Mode' settings. For example, if the 'From Standby Mode to Low Power Mode' is set to 10 minutes, then the 'Low Power Mode to Standby Mode' should at least be set to 11 minutes.
  9. Select the [Save] button.
  10. Select the [Exit Tools] button.
Sep 27, 2007 | Xerox CopyCentre C128 Black and White...
Konica Minolta Bizhub C550 Logo
423 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
