Question about Garmin nuvi GPS
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help Number
John Rosario
    New Friend:
When encountering errors such as "No Map Data Available" and Garmin Express does not recognize your Garmin nuvi, check to see if your Garmin nuvi is out of storage space from your computer. Solution related to the fact that when brought up as the E: drive in windows there were 0 bytes free space on the Garmin nuvi. To get Garmin Express to recognize a unit which is full, do a search on the Windows Drive (E:) for "gmap" then choose "Open file location" This will get into the hidden ".system" directory. From there, delete the largest file map, such as "gmapprom" (or move this file to your hard drive). Afterward, reboot your computer to have Garmin Express software recognize your Garmin nuvi. On older units, also purchase a microSDHC card to be able to store the newest maps, such as the US & Canada 2.6Gb map file, which will not fit on the internal unit alone or a 2Gb card. The Garmin Express software will recognize 4Gb to 32Gb microSDHC Class 10 or UHS-I cards formatted to FAT32 and install the newest maps automatically to them. Some have reported that 4Gb cards are not large enough. I had used a 16Gb SanDisk Ultra PLUS UHS-I card ($10.88 Walmart) successfully on my Garmin nuvi 1450LMT
Posted on Mar 20, 2018
5 Related Answers
banana45
SOURCE: Nuvi 350 System Software Missing
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
I got the same problem, after research on the web. Nick 99990_0 had post this solution on (his Nuvi 660) but it work for my Nuvi 350 too. Good luck.
Minh (NJ)
Posted on Dec 01, 2007
Anonymous
  • 171 Answers
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
Posted on May 12, 2009
Anonymous
  • 6 Answers
SOURCE: Garmin Nuvi 260w not recognized by computer
Take a look at this site, http://www.garmin.be/missing.html Download and unzip the software, plug your garmin in the USB and start the updater.exe program. It gets you started again. Later on you can use the Webupdater to get possible newer software..
It worked for me and my Zumo550
Goodluck
Auke
Posted on Jun 03, 2009
Anonymous
SOURCE: Hi, i need to do a "Hard reset" in my Garmin nuvi 1490
power the unit on and immediatly place your finger in one of the corners and hold it there. I believe it is the top right but if it doesnt work the first time try a different corner. This will reset the entire device and erase all settings.
Posted on Jun 30, 2010
Anonymous
  • 502 Answers
SOURCE: THE USB PORT THAT MY GARMIN NUVI 270 IS PLUGGED IN TO IS NOT RECOGNIZED BY MY COMPUTER
If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult to solder in a new USB port.
Posted on Jul 12, 2010
How do install/update my maps on a Garmin Nuvi 2597LMT??
Download and install Garmin Express from the Garmin site. Connect your GPS to your PC. The program will identify your GPS and let you update any software and maps that are available.
May 24, 2017 • Garmin GPS
4helpful
2answers
Is it my responsibilty to update the maps and traffic by calling you, or is this a feature that automatically happens with the garmin 1390lmt i just bought?
The updates are YOUR responsibility. Plug the unit into the computer and navigate to garmin.com, you can download maps and updates from their site.
There is no automatic update unless you navigate your browser to the Garmin site.
I don't know how to update my gps.
Welcome to FixYa.
To upgrade and/or update your Garmin GPS, do the following:
  • To update your Garmin device, go to this link https://my.garmin.com/maps/chooseDeviceType.htm?
  • Select your device type.
  • It will request to install the Gamin Communicator Plug-in.
  • Make sure that you connect your Garmin device to the computer before proceeding to install.
  • After the installation, it will automatically download for an updated map.
Note: Sometimes, there are no available updated maps.
To confirm if there are available maps, contact Garmin:
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Thank you for using FixYa.
Have a great day.
Cant download update for maps
Welcome to Fixya.
Different manufacturers have different ways of updating their GPS devices. Assuming you own a Garmin GPS device, regardless of its model, here is how to update:
Welcome to FixYa!
  • To update your Garmin device, go to this linkhttps://my.garmin.com/maps/chooseDeviceType.htm?
US: 913-397-8200
Have a great day.
Jul 12, 2011 • GPS
2answers
How do i update
You need to connect the USP cord to the unit and connect to your PC. Go to the Garmin web site and click on update maps or update firmware (whichever it is you are trying to update) and follow the instructions explicitly.
2answers
Need update
go to www.garmin.com and follow the link for the update service
1helpful
My GPS stoped working sudenly
get it on to charge for atleast an hour and then connect it to garmin.com through ur PC. Pls click updates and see if any update is available to install. install if there is any. and try to turn it back on.
Need to update
I can help you update your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
StreetPilot C330
Go to www.garmin.com and read about "Map Updates" Enter your unit's serial number and see if there's a newer map available. It will explain about how to buy and install the update.
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
