Question about InFocus Projector Lamp for IN24+, IN26+
SOURCE: InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Posted on Feb 02, 2008
SOURCE: InFocus LP280 problem
Hi there
I'm afraid this might be a faulty Mainboard.
Your lamp will never make the Projector show funny stuff on the image.
Must warn you that a new Mainbaord is quite expensive
Posted on Apr 02, 2008
SOURCE: Infocus LP820 - Turns on for 30sec then shuts down
This could be one of two problems I have seen with another model Infocus projector (they are very good projectors though)
The first is the video input. Make sure it is attached correctly at both ends of the cable.
The second, remove the dust covers and blow them out. The problem can arrise if the temperature sensor detects the air inside the unit is getting too hot. If you can see the sensor when the dust covers are off (it will look like a little lump of goo on the end of a wire) then just give it a wipe as well. If dust settles on those it can cause incorrect temps to be reported.
Hope that solves your poblem =)
Posted on Apr 11, 2008
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
SOURCE: infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Posted on May 06, 2009
May 04, 2011 | InFocus In2102 Projector
Mar 29, 2011 | InFocus In2102 Projector
Feb 08, 2011 | InFocus In2102 Projector
Jul 20, 2010 | InFocus LP 530 Multimedia Projector
Mar 09, 2010 | InFocus X1 Multimedia Projector
Dec 29, 2009 | InFocus X1 Multimedia Projector
Nov 04, 2009 | InFocus In2102 Projector
Aug 10, 2009 | InFocus X1 Multimedia Projector
Jun 29, 2008 | InFocus IN72 Multimedia Projector
Sep 18, 2007 | 3M Projector lamp Projector Lamp
Jan 22, 2018 | InFocus Projector Lamp for IN24+, IN26+
