If all the display lights on your GE dehumidifier ADHL35 are flashing, and the alarm is sounding, it indicates that the dehumidifier has detected a fault or an issue that needs attention. The specific problem could vary, but here are some common reasons for such an error:
- Full Water Tank: The most common reason for alarms and flashing lights in dehumidifiers is a full water tank. Check the water collection bucket or reservoir to see if it is full. If it is, empty it and make sure it is correctly repositioned in the dehumidifier.
- **Air Filter: **Some dehumidifiers have a filter that needs regular cleaning or replacement. A clogged or dirty filter can trigger an alarm and flashing lights. Check the user manual for instructions on how to clean or replace the filter.
- Temperature and Humidity Levels: Extreme temperatures or high humidity levels can affect the dehumidifier's performance. Ensure the dehumidifier is operating within its specified temperature and humidity range.
- Obstruction in Airflow: Make sure there are no obstructions blocking the air intake or discharge vents of the dehumidifier. Blocked airflow can affect its operation and trigger an alarm.
- Internal Malfunction: If none of the above issues are the cause, there might be an internal malfunction in the dehumidifier's electronics or sensors. This could require professional diagnosis and repair.
Here are some steps you can take to troubleshoot the issue:
- Turn off the dehumidifier, unplug it from the power source, and wait for a few minutes before plugging it back in. This can help reset the electronics.
- Check the water tank and empty it if it's full. Ensure it is correctly positioned and seated in the dehumidifier.
- Clean or replace the air filter if necessary.
- Ensure there are no obstructions blocking the air vents.
If the problem persists after attempting these troubleshooting steps, it's best to contact GE customer support or a qualified appliance repair technician. They will have the expertise to diagnose and fix the issue properly. Avoid using the dehumidifier if it continues to display an error or alarm, as using it in a faulty state may cause further damage or pose safety risks.
