Question about Nordic Track X11i Commercial Incline Trainer Treadmill
How should I lube my NORDICTRACK X11I - Nordic Track X11i Commercial Incline Trainer Treadmill
Posted by monicatricru on
Electro Med Services
  • Nordic Track Master
  • 6,694 Answers
Check the video all the treadmill follows the same procedure of lubricating it.
Posted on Oct 11, 2013
NordicTrack elliptical 1055 model 90952 incline ramp will not go down
You must take out the cover, and examine if there
are part with lack of LUBE, and corroded.
Normally this happen because the equipment has NOT maintenance in the time, determined by the factory.
Proceed according. LUBE.and repair
Blessing
[email protected]
cell+whatsAPP:+50588611441
Oct 25, 2017 | NordicTrack Exercise & Fitness
I have a NordicTrack EXP1000 that completely shuts off after 9 minutes! We lubed the belt, and it did seem to be slipping slightly, but not very much. (We lubed it after realizing it hadn't been done in a...
I had a similar problem. Mine was shutting off and also some of the buttons worked intermittently. I thought it was overheating so I bought a small fan and I even went so far as to drill holes in the cover near the motor so the fan would cool the motor better. Turns out it was the console overlay. I purchased a new one from the Treadmill Doctor since NordicTrack will only sell you the entire console, not just the overlay and they want somewhere north of $400 for it. All I had to do was remove the console cover, unplug the old console overlay, peel it off and then stick the new one on and plug it in and I've had no problem since then. It's been over 5 years now since I did this and if I recall correctly the overlay was around $100. Good luck
Aug 15, 2013 | Nordic Track Nordictrack Exp 1000...
Contiually beeping, when started it stops a few seconds later
LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
Treadmill belt stops abruptly
This happen because the lack of LUBE in the machine according with the instruction maintenance.
Please see the video and proceed according , LUBE the rollers bearing too.
God bless you
Jan 07, 2013 | Nordic Track Nordictrack A2350 Treadmill...
NordicTrack Classic Pro Skier has a noisy pulley
1) LUBE the deck belt inmediately, maybe you have now a WORN deck belt time to replace.
2) LUBE the rollers bearing TOO.
3) test the voltage input motor, if there are the motor NEED repair
God bless you
Oct 14, 2012 | Nordic Track NordicTrack Classic Pro Skier
Nordictrack c1800 goes into cool down mode at the start and then stops
Lube the treadmills deck belt inmediately
2= lube the rollers bearing too
3=measure the input voltage motor, if there are the motor need repair
4) measure the output board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Jul 03, 2012 | Nordic Track Exercise & Fitness
NordicTrack treadmill squeaks when walking but fine when running.
1) lube the deck belt, and possible the deck is worn must be replace
2) lube the rollers bearing too.
3) test the bearing motor, need replace too.
God bless you
Jun 17, 2012 | Exercise & Fitness
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Nordictrack treadmill C2100 belk is not slipping motor stops when you step on treadmill at low speeds, step back off and it starts working
Several issues, drive belt that drives the walking belt could be loose but you should smell rubber if its slipping.
Something could be caught in the track causing extra drag, its easy to do if you have kids or pets
Check for when you last lubed the track and walking surface, with no silicone it will drag and bog at low speeds
Oct 21, 2009 | NordicTrack Exercise & Fitness
Nordic Track X11i Commercial Incline Trainer Treadmill Logo
523 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
