Fuji FinePix S5100 Digital Camera Logo
Question about Fuji FinePix S5100 Digital Camera
Button sticks when taking picture
Posted by agibbs935 on
The shoot button has popped off. It won't stay on the camera. If I stick a needle down the hole it will take a picture, so the camera works fine. It's just the button
Please don't stick anything in there to take a picture, especially a needle!! Your shutter button needs to be replaced, its a very common defect on this camera.
There is only one place that will install a new solid aluminum shutter button post and guarantee it will never break again! How do I know? Because I've been repairing them since 2006 and I own the shop with the aluminum posts!
Thomas Drayton
Owner, www darntoothysam com Affordable Digital Camera Repair
I need to selectively delete some pictures from my memory stick
The button with the icon of a garbage can is the delete button. Bring up a picture you want to delete and press that button...follow the on-screen instructions.
Oct 19, 2009 • Cameras
Delay when taking picture
2 things to be checked to rectify this delay.
what size of memory stick you are using. 1GB is fine, 2GB slower the camera and 4GB is more then enough.
Check memory stick, is it full with files? try to make more free space in memory stick.
perform "intialization" by selecting in camera menu.
Good luck.
Photo problem. sony cyber-shot 10.1 MP silver touch screen
Take out memory stick, connect camera with PC, go to Removable Disk, go to folder and copy that picture. Simple !
Memory full message in error
Remove some pictures from the memory stick Or copy them to your computer. Actually your memory stick is full. If you have no memory stick in the cam then purchase a new one for it. The cam memory is not enough to store many pictures.
2answers
Please help: readout says "no memory space" but memory stick is empty!
When you copy pictures to your computer you still have the pictures on your camera so there is need to clean them up my reformatting memory stick.   This procedure will leave the memory stick clean and ready for a new set of pictures.  Here is how you reformat the memory stick-:
1.  Insert the memory stick to be cleaned/formatted in the camera
2.  Turn the MODE DIAL to the SETUP position on the camera
3.  Switch on the camera
4.  Select the MEMORY STICK TOOL from the CONTROL BUTTON
5.  Press the centre of the CONTROL BUTTON
6.  Select FORMAT by using the down arrow and up arrow
7. Choose OK by moving the right arrow button
8.  Finally press the centre of the CONTROL BUTTON and this will start reformatting the MEMORY STICK and it will ready for reuse.
Enjoy your new space in your Memory Stick!
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
11helpful
5answers
Deleting pictures from camera....
press menu
go to setup
scroll down to the second option: memory stick tool
go to format
re-set the format to "ok" even if it says "ok" already
press ok to all dad in memory stick will be erased, ready?
and all the pics will be deleted. thats the problem with this camera, everything is good except trying to figure out how to delete them all!!! ughh
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Top Fuji Cameras Experts
Steven Wander
Steven Wander
David Shaub
Steve Nordquist
Steve Nordquist
Are you a Fuji Camera Expert? Answer questions, earn points and help others
