Question about Yamaha Electrical Supplies
Yamaha ef3000ise shuts down after start up
Start it and it will run for a min or so and shut down 3-4 times the low oil light comes on, but then its fine the oil level is fine what could the problem be?
Posted by Joni Davis on
Alan Gowar
    Master:
  • 452 Answers
Replace the low oil light censor, that's ur problem giving false reading
Posted on Oct 11, 2013
5 Related Answers
hawkchuck
  • 4 Answers
SOURCE: powermate 5000 subaru moter the gen runs for 1 mn and shuts down
oil level is low???
Posted on Dec 19, 2008
farfield
Farley Redfield
  • 462 Answers
SOURCE: Generator won't run
DId you change the oil filter when you changed the oil I am assuming it has one.
If it has a filter some of them have a check valve in side and this valve may not be operating properly.Also you might try rolling it over a few times with the pressure sensor removed and see if oil spurts out the opening. If so then the problem may be the oil pump not building up oil pressure, or the motor may have a board looking for the oil pressure sensor to close (or open depending on how its engineered) and the sensor board is not working properly or not grounded good. Try cleaning the battery cables just in case (assuming it ahs a battery).
Posted on May 08, 2009
Anonymous
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
Fred Yearian
  • 5603 Answers
SOURCE: Gen runs for 8 min then shuts down most of the
Check for intermittent oil pressure switch. Monitor the possibility of low oil pressure shutdown.
Posted on Mar 23, 2010
Anonymous
SOURCE: Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Posted on May 06, 2010
2006 vector get flashing oil light twice then shuts down
Maybe its trying to tell you something. Low oil or no oil flow, try replacing level sensor.
Feb 15, 2016 | Yamaha 2006 RS Vector GT
Why does it shut down while driving?
First, do not run engine low on oil. Next, run tests when it has failed. Spark to plugs? Correct fuel pressure?
Aug 11, 2015 | 2002 Mitsubishi Galant
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
Ef3000iseb runs for 5 minutes and then shuts down
u must clean the carburetor something stuck in there
Apr 16, 2013 | Yamaha EF3000iSE Generator
Yamaha 2000 run poorly at higher altitude
What elevation are you at? Start with simple things such as clean the air filter, fresh gas, clean/replace spark plug. Also check oil level most generators have a low oil shut off yours may be attempting to shut down
Jul 26, 2012 | Yamaha Sidewinder Twin Tech Generator...
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
Electrical Supplies Logo
260 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
