Garden Logo
manuel serra Posted on Oct 07, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
morrispd_75
Level 2:
  • Expert 108 Answers
  • Posted on Oct 07, 2013
morrispd_75
Expert
Level 2:
Answers
108
Questions
0
Helped
20224
Points
303
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
5 Related Answers
Anonymous
  • 57 Answers
  • Posted on May 18, 2009
SOURCE: Changing blades on riding mower
Must be able to get to underneath side of deck obviously. If you do not have access to impact tools, it is usually easiest to remove the deck as you must keep the blades from turning. Place a block of wood to where it will jam the blade while attempting to turn the nut. (7/8" socket or wrench). Usually very tight, try some penetrating oil to help.
gejandsons
  • 33 Answers
  • Posted on Aug 21, 2009
SOURCE: cub cadet riding mower blade won't turn on
If the click you hear is the electric PTO engaging, then your deck belt is broken or off a pulley some where. Check the belt & then clarify if needed
Anonymous
  • 388 Answers
  • Posted on Sep 11, 2009
SOURCE: when I engage the mower blades,It makes a loud
It sounds a lot like the balancer is loose. You can most likely fix this yourself, here's how: pull the spark plug wire off the plug, tilt the lawnmower up to expose the blade, rock the blade to see if it is loose on the shaft, if it is all you have to do is tighten the bolt so the blade and the balancer are flush to the shaft. That should fix your noise and uneven cut problem. If that doesn't fix it, let me know here, ok? Cheers!
Anonymous
  • 78 Answers
  • Posted on Oct 29, 2009
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on May 26, 2010
SOURCE: Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
My riding lawnmower not cutting even, craftsman 46"
first check that the blade or mandrel is not bent or damaged --and check the air pressure in tires on right side --lower deck towards ground on a level surface until left makes contact now adjust the level arms they are on either side of cutter till right side is level with left on some of the older decks can adjust the front deck wheels also
I have an 07 craftsman 24 ohv, 42 " cut riding
Left blade is on backwards (liftng edge is contacting grass). Try reversing the blade on the left side.
Jun 15, 2012 • Garden
4helpful
4answers
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
1helpful
2answers
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
1helpful
2003 DLT3000 Craftsman riding mower. Air in tires correct, deck level front/back & side/side, new blades.. Still cuts uneven. Does this deck flex when cutting tall grass & how do I fix this...
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
2helpful
2answers
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
1helpful
Cutting unevenly
Set the mower on a known flat piece of concrete. Now look at the deck and the support connections where the deck hangs from from the mower. Should be adjustments such as pins with clips or threaded bolt hangers which will allow you to raise or lower the corner of the deck which is low or high. Conversely you could have put a blade in upside down or left out a washer making one blade higher than the other. Usually an owner's manual will detail this process. As you just changed your blades, as opposed to wear and tear, likely you did not put it back together exactly as you took it apart.
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
12helpful
3answers
Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
