Question about Lenovo ThinkPad R60 Notebook
My Fn+F5 shows nothing to turn on/off wifi in lenovoz580.. Any solution for this or alternative to turn on/off wifi through command prompt?
Posted by srihari on
k24674
  • Lenovo Master
  • 8,091 Answers
You can go the hardware (device) management and unload the drivers or uninstall the device. You may also have a switch on the sides of your laptop.
Posted on Oct 07, 2013
1 Related Answer
SOURCE: Hi, My fn+f5 key doesn't work,
Here's a comprehensive guide on troubleshooting bluetooth problems. click here
Posted on Mar 25, 2011
My Lenovo z580 shows nothing when i tried to turn on my Wi-Fi by pressing Fn+F5. Any solution or alternative to turn on wifi?
Reinstall the WiFi driver:
Lenovo Support Drivers Software US
Alternatively, you can Enable/Disable WiFi by opening:
Control Panel>Network and Internet>Network and Sharing Center>Change Adapter Settings
You should see your WiFi connection listed. Right Click to Enable or Disable.
Oct 07, 2013 | Lenovo IdeaPad Z580
How can I turn on a wireless capability on the lenovo laptop? I have tried Fn+F5 and the front switch is on. Please help me.
Aug 31, 2013 | Lenovo Computers & Internet
Turning on the wi-fi, toshiba satellite l505-s5966
Turning on of wifi in laptops are usually done using the keyboard's function key and a Wifi button located from F1 - F11. Also a LED light indicator is placed somewhere in your Notebook, Which will tell you if your wifi is turned On/Off. So here is what you must do.
  • First try to locate your wifi button which is located from F1 - F11, it has a small logo like an Antenna with a signal wave on both sides.
  • Now when you found the botton, for example in "F5" , Hold and press the Function Key which is the "FN" then press the wifi button which is the "F5" in short presentation is this " FN+F5"
  • Remember to press it only once because pressing it twice will result in an off wifi. So be sure to press it only once.
  • After pressing it, a LED light should turn on, it is located somewhere in your notebook. When this light is on this means that your wifi is already turned on.
  • and Thats it.
Hope that my solution will help.Thank you for using Fixya!
Jul 07, 2011 | Toshiba Satellite L505-S5966 Notebook
M using windows 7 - 32 bit OS... i got my laptop repaired and wifi wires too but now wifi is not working properly... wifi is able to detect all signals except the wireless internet network signals.... i...
some more information would be helpful ;-)
I.e. one important information is, which laptop it is.
For the wireless adapter seems not to be usable, the os might not corresponding correctly with it. Please post your laptop model type. Another driver for it's wireless adapter might fix this problem.
Greets
Mitch
Feb 18, 2011 | Computers & Internet
Why when I turn on my wireless indicator it doesn't turn on??
>check if your wireless adapter is on
>press Fn+F5
>check the status of your wireless adapter
>if it is off turn it on
Jan 06, 2011 | Lenovo G560 06793JU Notebook
I can't turn on my wifi connection
try hitting FN+F5, so the function key and the f5 key at the same time function is listed as fn on the keyboard you will then get the option to turn on
Jan 05, 2011 | IBM ThinkPad T43 Notebook
Cannot turn on wifi on T400. Intel 5100 card
Is the "broadcast-tower" light on (the leftmost icon on the lite-bar below the screen)? Have you got an available/working WiFi router? Have you been able to choose a network to connect to? My T400 works fine when all the above are enabled..
Jun 18, 2017 | IBM ThinkPad G41 Notebook
Lenovo T61 Wireless not connected
To turn on the wifi card. Make sure that the driver is install the press FN + F5.
Thanks for using Fixya.
Oct 14, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad R60 Notebook Logo
111 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
