LG W2042S 20 inch LCD Monitor Logo
A
Anonymous Posted on Oct 07, 2013
Driver windows xp 7 - LG W2042S 20 inch LCD Monitor
Windows 7 fargo printer drivers
There are no Windows 7 printer drivers available for the Pro-L printer. You may try using the original Windows XP driver if you know how to setup a virtual XP environment in Windows 7 Pro. This requires you to install the printer and the software that uses it inside the virtual XP.
1helpful
3answers
Scanner doesnt have a driver for windows 7
This may help. Depending on your version of windows 7 you may be able to run Windows XP as a virtual machine and still user your scanner under XP Mode. You will have to install the XP driver for your scanner on the XP virtual machine running on your Windows 7 computer.
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software.
HERE is the direct link to instructions on downloading and using XP Mode on Windows 7
2answers
Can windows XP be install on HP Pavilion dv7-1132nr with Vista OS
Yes, You can dual boot Windows XP and Vista but you'll be having problem finding drivers if you install Windows XP on this computer since Windows XP supported drivers aren't available on Hp download page. HP has only Windows Vista and Windows 7 drivers for this System.
Hope this helps.
Good Luck.
Thanks for using FixYa.
My LG X200 works with Windows 7. Can I install XP on this model. And if I install XP, the drivers available for windows 7 will work on XP?
The drivers for Wndows 7 most likely will not work on Windows XP.
If this laptop came installed with Windows 7 it may not have Windows XP drivers.
Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
2answers
How i intall my Graphic driver for windows 7 because i do not have the driver for windows 7 in my mother board cd.
Hi
It doesn't seem that there are Windows 7 drivers for your motherboard (I'm assuming you're talking about your onboard graphics) - See here.
The best option you have is trying to install the VGA drivers for Windows 2000/XP and hope that works. Otherwise you're going to have to revert to Windows XP for your grapics to function correctly.
Another option you have is installing a 3dcard on the motherboard. Click here for a complete list of graphics cards supported.
Good Luck,
-LL
2helpful
2answers
My windows always crash when i play any video files. for my driver under window 7 is the the driver i have for win xp
download this:
http://www.nvidia.com/object/winxp_2k_71.89.html
I used version 93.71 and it crash.
this version will make your 3d stuff work.
and put it in xp mode.
there won't be aero.
33helpful
5answers
CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
