Mine did that. Little known that the Grundfos MQ pump has a small pressure tank on the end. If the pressure is low and the air volume is therefore low, then any tiny loss of water results in pressure drop and pump cycles on. Check the pressure in the tank. This is not well described in the Grundfos service manual.
To pump up the pressure bladder:
1. remove the rear cylindrical cover (swift bash with a fist downwards)
2. unscrew plastic cap on the end (about 2 inches diameter with tapered sides
3. attach pump to schrader valve and pump up (22-25 psi according to service manual)
Reassemble.
Suggest teflon tape to schrader valve stem to try to create a secondary airtight seal.
SOURCE: pump cut out. primed pump and restarted but keeps
Here is a tip that will help you..
Jet Well Pump Well Jet Water Pump
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
heatman101
SOURCE: grundfos mq3-45 pressure booster pump
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
