Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
may be a bad thermal shut off , any error codes like F1 may also want to check ur push start button or dial with a multimeter, if its bad can get a buzzing and maybe a clicking
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
