Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
I have a go go elite traveller plus , the battery pack will not lift off my scooter it seems to be stuck , i need to replace the batteries
Posted by jo parker on
littleone121
    New Friend:
  • 23 Answers
The manual for this scooter is at http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
The closest info I can find is page 14. MOVING AND TRANSPORTING YOUR Easy Travel Elite
6.1. Moving Your Easy Travel Elite in Freewheel Mode when unfolded:
The Freewheel switch (Fig. 1/17) is used for releasing the brake and moving the Easy Travel Elite without operating the motor. Before activating, make sure your Easy Travel Elite is switched on. Turn Freewheel switch to the "freewheel" position and push or pull the Easy Travel Elite manually.
NOTE: The Freewheel mode can only be activated after the battery is in place and the power switch (Fig.9/1) is turned on. Doing otherwise will cause a fault situation indicated by rapid flashing of the Indicator light (Fig. 9/4). See section 4.2.
WARNING: The Freewheel switch should never be engaged on a slope.
CAUTION: The seat back must remain in the upright position.
They seem to assume removal is obvious, I would check any connections from battery to scooter are pulled out and that freewheel mode is not engaged.
Posted on Oct 22, 2013
  • Don Wilson
    Don Wilson May 11, 2017
    The battery is just ljfted off by lifting the handle at top front, there are no fixed connections to battery just the handle ..
5 Related Answers
lennieg2000
  • 692 Answers
SOURCE: I need immediate help with
Check the area at the rear of the motor where the brake is attached after operating for a while if you can feel heat or hot at the brake motor area then the brake is sticking causing excess drag this in turn drains the batteries quicker and can be the cause of the clicking sound you hear. If the battery is not getting hot or the motor then the problem could be in the transaxle. Block the rear wheels off the ground and have the wife engage the throttle if you still hear the clicking noise place your hand on the gearbox /transaxle to see if you can feel a vibration in time with the clicking If you feel a vibration then the transaxle/gearbox will need to be changed If you see that the brake is dragging then the brake will have to be replaced If Medicare paid for the wife's scooter then they will pay for 80% of the repair. You can contact the provider that sold your wife the scooter to see if they do repairs or you can contact Repair xpress @1-877-581-3733 to see if they have a tech in your area Hope this helps you
Posted on Apr 21, 2011
Barry Nixon
  • 103 Answers
SOURCE: charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Posted on Jul 23, 2009
Barry Nixon
  • 103 Answers
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Posted on Dec 16, 2009
Paul B
  • 61 Answers
SOURCE: battery won't hold a charge
More than likely duff batteries. Will it hold its charge if the batteries are taken off the scooter (i.e. remove the battery pack)? If so, it could be a short somewhere in the wiring of the scooter although I would have to say that this would be unlikely.
Posted on Mar 19, 2010
Anonymous
  • 26 Answers
SOURCE: i have a go-go elite traveller scooter and the
if light does not work fault in wiring or connection
Posted on Apr 15, 2010
I am travelling by air next week and I need to know the serial no. of my scooter. Where do I find this. I have a 4 wheel Go-Go Elite Traveller Plus Hd
hi , its located on the bottom part of the seat stem , you will need to remove the seat and battery pack to see this,
Regards
Jan 25, 2013 | Pride SC53HD GO-GO Elite Traveller Plus HD...
Battery stuck on Pride mobility scooter
Hi. There are no locking devices on the GoGo Elite Traveller series of scooter. The Battery pack simply lifts off. However, they can be very tight and sometimes require a sharp tug upwards to remove them.
Hope this helps.
Jan 02, 2013 | Pride Health & Beauty
Have got 4 year old traveller plus both lights on the charger do not come on when plugged in
The 17 amp hour batteries on this scooter rarely last more than 1.5 years. If the batteries are 4 years old, find some replacements on-line. With a long phillips screwdriver it is easy to open the battery box and replace the 2 batteries yourself. You should check the 2 fuses to make sure they are not burnt open and are making good contact. Hope this helps
Jul 03, 2012 | Pride Mobility Products Go-Go Elite...
I have a pride go go elite traveller 4 and need some new batteries, but what batteries and connection am i looking for?
Rachel you need 2 12/12AH batteries that are located in the battery pack under the seat. Simply pull the battery pack from the scooter and with a standard phillips screwdriver remove the many screws attaching the battery pack together (simply turn the pack over to get to the screws) There will be two wire on each battery and also a heat sensor attached to the side of one battery remove the wires from each battery and carefully reove the heat sensor. You can bring one of the batterys to your local battery warehouse type store or a provider and purchase 2 new ones reinstall like you removed attaching red wire to red terminals and black to black terminals and reattach the heat sensor to the side of one battery (you can use packaging tape to reattach). replace all the screws to put the case back together and reinstall in your scooter. Charge the batteries with you charger until the charge light is green then happy riding HOPE THIS HELPS
Aug 20, 2010 | Pride Mobility Products Go-Go Elite...
How do i remove battery on a go go scooter to replace it.
it should simply lift out and the whole unit is replaced by a new one. Hope this helps. Steve.
Dec 29, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Go Go Elite Scooter - charger location problem on scooter
This is because of the inhibit circut, there is no good way to disable it, how ever one suggestion is to simply lift the battery pack off the chair and place it on a table or counter top so getting to the charger port is easier. The batteries don't have to be on the chair to charge them.
Jun 20, 2009 | Pride Mobility Products Go-Go Elite...
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
636 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
