This is very common issue you face mostly and it may harm your printing job.
Reasons for Brother Printer Error 72
Kindly find underneath the potential conditions which may cause this error.
One of the reason might be buildup within the printer if it's not working appropriately.
It might likewise happen as a result of the temperature differential among inside and outside of the printer gadget ("20-degree Celsius to 32.5-degree Celsius").
In the event that you get this Error "Print Unable 72" at that point keep track on your PC that when and where this error happened so you can oftentimes investigate this issue and dispose of it in a split second.
Steps to Resolve Brother Printer Error 72 "Print Unable 72":
If it's not too much trouble follow the beneath offered steps to explain this printer Error "Print Unable 72" from your Brother gadget.
Arrangement 1
Right off the bat, turn OFF the force supply of the printer.
Presently, hang tight for few moments and afterward switch ON your printer.
In the event that it shows-up date and time, at that point attempt to direct a test print as your error has resolved.
In the event that you see Print unable 72 message once more, at that point proceed with the underneath given Solution 2.
Arrangement 2: Brother Printer Error Print Unable 72
On the off chance that you have any fax in your printer's stockpiling, at that point move them to another Fax machine or printer.
Presently, go to the printer menu and press 9, 0, 1 to check for the spared faxes.
The menu will show up just when the LCD or the printing machine confronting an error
On the off chance that you get some other error in the wake of restarting your printer, so all things considered, you won't locate any numeric alternatives.
On the off chance that you have no fax in the memory, the LCD show will show up 'No Data' message.
Presently, proceed onward "Guarantee AND SERVICE OPTIONS" referenced beneath.
On the off chance that any fax evacuated in the printer memory, you have to move all the spared fax from another gadget.
Suggestion The Station ID is as of now customized in the machine before the message begin to show while you move the information from Brother Printer to another machine.
Presently, type your moving fax number to the gadget, select "Dark Start".
Presently, began with the "Guarantee AND SERVICE" choices.
When your fax(s) are moving to your PC, ensure you have MLF professional suite or any supporting programming introduced before sending them.
Subsequent to finishing all the procedure, press "Stop"
Presently, go to the printer menu choices and select "Fax, Remote Fax pick, Fwd/Page/Store".
At that point, pick PC Fax Receive by spending or Down bolt.
Subsequent to following all the above advances, you will get an affirmation popup message, at that point click "alright".
Presently, restart your printer and step through an examination print.
On the off chance that you discover error once more, you can take the help of Brother printer client care.
I hope this will work for all of you and in case still facing this error you can contact to Brother Printer Customer Support Dial +1 866-231-0111
SOURCE: i have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
ERROR 71 &72 ARE PRINT CARTRIDGES CHANGE THEM OR INSTALL THEM CORRECTLY
