Lenovo IdeaPad Z570 Notebook Logo
Sachin Jadhav Posted on Oct 07, 2013
I dont have a bios password key and i want to remove bios password
philip
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Oct 07, 2013
philip
Contributor
Level 1:
New Friend:
Answers
34
Questions
Helped
4411
Points
73
Tricky you need to remove all power (including the on board battery) and leave for at least 24 - usually 48 hours. Then plug back in all batteries and you should be OK.
I ned help to remove bios password on my lenovo g40-30 laptop motherbord please
  • Turn the Lenovo computer off. Leave the computer off for at least five seconds.
  • 2 Press and hold down the "F1" key. Turn the computer on.
  • 3 Release the "F1" key when the BIOS screen appears.
  • 4 Type the current BIOS password into the password field.
  • 5 Click the "Password" button. Select the "Supervisor" icon.
  • 6 Type the current BIOS password into its field. Press the spacebar.
  • 7 Press "Enter" on the blank password box. Press "Enter" on the verification screen. The BIOS password is removed.
  • 8 Click the "Save and Exit" icon.
  • Read more : http://www.ehow.com/how_8577037_remove-bios-password-lenovo.html
    tip
    Toshiba Laptop BIOS Password Removal
    <span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
    on Jun 09, 2011 • Computers & Internet
    Dont know the bios password
    You do not need to pull apart your laptop to clear the BIOS password.
    This WEB site shows you how to remove the BIOS password.
    http://www.digitalbart.com/blog/toshiba-satellite-a665-s5170-bios-password/
    4helpful
    3answers
    I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
    My sister gave me a Compaq evo computer. When i turn it on it goes right to a screen that says Power-on password with a picture of a key. She doesn't know what the password was and it doesn't let...
    It seems to be BIOS password, if you don't remember or don't have the BIOS password you have to reset the password by opening your CPU cover and removing the CMOS coin battery, this will reset the BIOS password but dont forget to return back the battery and start using your PC.
    Regards,
    JJ
    Becouse i dont remember my new password..plz help me becouse i dont open my fb..thank you..
    click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
    also
    When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
    If you are talking about problem with your password
    You need to prepare:
    1:A blank CD/DVD or USB flash drive
    2.A computer which can link to internet
    3.A program called Windows Password Recovery 6.0
    or
    Get started with this 3 simple steps:
    Website: http://lost-password.net/products/windowspasswordrecoery.html
    Step 1 - Download windows password recovery utility and install it.
    Step 2 -Burn your Windows Password Reset CD:
    To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
    Step 3 - Put in your newly created CD and remove your Windows password.
    hope this helps
    or
    http://majorgeeks.com/download.php?det=5710
    UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
    you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
    there are a number of things that you can do to remove your password another option would be to remove your cmos battery Hope this helps
    3answers
    How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
    B I O S P A S S W O R D
    Setting the BIOS Password
    There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
    Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
    If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
    Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
    To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
    ESC key BIOS Password setting procedure
    1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
    2. Press the F1 key. The BIOS setup program will appear.
    3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
    4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
    5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
    6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
    F2 key BIOS Password setting procedure
    2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
    3. Use the arrow keys to move to the Security tab.
    4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
    (It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
    5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
    6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
    7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
    8. Press the F10 key to save changes and exit the BIOS Setup program.
    HWSetup BIOS Password setting procedure (This method works for most notebook models.)
    1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
    2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
    (If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
    3. Click on the Password tab.
    4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
    5. Enter a new password at the "Password = " prompt, and press the Enter key.
    6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
    8. Close the HWSetup program.
    _______________________________________________________________________
    Removing the BIOS Password
    Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
    HWsetup BIOS Password removing procedure (This method works for most notebook models.)
    4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
    5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
    6. HWSetup should now show that the password is Unregistered, which means there is no password set.
    7. Close the HWSetup program.
    Trus this is helpful. Please vote. :)
    Computer has been working fine. Now all of a
    When system boots press the key to get into BIOS. Usually it is 'Del' Key. Once you get into BIOS, if not asking a password, get into admin menu and set the password option disabled.
    If asking for a password while you get in to BIOS and you dont know the password, the only option is to reset the BIOS.
    To reset BIOS u've to remove the back cover and remove and re-insert the CMOS battery while the laptop is powered off. After that, power on the laptop and set the bios to normal setting, especially the time. This wont harm any of your data.
    Please come back and vote for me if this finds helpful for you. Thnx
    2answers
    Toshiba l300 1bv bios password forgotten
    Download and flash your BIOS to the newest version for your make and model. You have four to choose from. There are known issues with Toshiba BIOS's, this is one of them.
    http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
    Hope this helps.
    Edit: some notebooks use "Toshiba" or "toshiba" for their password.
    Or try this: From Toshiba website http://tinyurl.com/dkoudz
    1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system Then press (F1) key" appears on the screen.
    this might be what you are after
    http://www.pwcrack.com/bios.shtml
    Also have you read through this site?
    http://www.tech-faq.com/reset-bios-password.shtml
    Top Lenovo Computers & Internet Experts
    Steve Sweetleaf
    Steve Sweetleaf
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
