SOURCE: E2111 SBE log disable DIM2
replace system memory, that indicates on lcd screen #dimm...#. In this case, dimm2.
SOURCE: E2111 SBE LOG Disable DIMM
The E2111 should also indicate a number after the DIMM, this is the bank of the DIMM it believes to be bad. Depending on your support contract situation, and ability to bring down the machine, reseating the module after cleaning it a bit with some good old 'canned air' may do the trick. Otherwise a module replacement is in order which is typically covered by DELL if you are still under coverage.
