Question about Integra Audio Players & Recorders
Hdmi not working on integra DTR 8.8 - Integra Audio Players & Recorders
4 Related Answers
Anonymous
  • 33 Answers
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
Anonymous
SOURCE: the reciver dosnt get a signal from the hdmi
HAVING THE SAME PROBLEM. omg. maybe there is help. will get audio but no video from DPS dvd player and PS3. no onscreen menu either. changed hdmi cord. seems to be problem with reciever. DVD works fine when changing to component cables instead of the HDMI. sometimes plugging and unplugging the HDMI cable gets the PS3 working. Don't quite understand scrap605's suggestion. but that doesn't solve this prob.
Posted on Mar 07, 2010
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: my integra dtr 5.6 receiver
hi,
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
Posted on Jul 30, 2011
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: my integra dtr-40.2 reciever will
Please unplug the unit from the outlet for 15 mins and then check if the symptoms still there.
Reset the unit to factory setting by following the steps below.
> Power on the unit.
> Press VCR/DVR button key + On/standby key at the same time to re-initialized the memory to factory settings.
Check also if the remote control is working fine. Aim the sensor of the remote control directly to your cellphone camera, while pressing any button key from the remote control (button key with an issue) you will be able to see the flash of an infrared emitted by the remote control indicating that it is working fine. Watch the video below for more info.
Jdvillanueva
Posted on Sep 13, 2011
Is drt-20.3 compatible with windows 8?
Yes after software up dates via integra web site
Aug 09, 2014 | Integra DTR-5.2 Receiver
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Jun 30, 2009 | Integra DTR-5.2 Receiver
171 people viewed this question
Top Integra Audio Players & Recorders Experts
Bill DiBrino
Level 1 Expert
Naheed Mir
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
