I have a weaver tactical 4.5-14 X 44 Scope. the turret for elevation was turned all the way up, now it's locked (or jammed) I do not want to use extra pressure afraid to mess it up. any suggestions?
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
SOURCE: I need covers for the adjustment turrets on a 6x24
most likely you will have to send the scope in to have this taken care of to contact bushnells customer service at 800-423-3537. press option 1.the age of the scope necessitates having the scope to match parts.
SOURCE: My Bushnell Banner rifle scope
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
