SOURCE: ERROR CODE 18H
18h is not an error code error codes will be displayed be an E followed by numbers this sounds like delayed start try hitting cancel then if that don't clear it try unplugging the unit for 5-8 seconds let me know if that don't clear it and we will run diagnostics on it
SOURCE: does not finish cycle, gives error 20
After reading what others said on how to fix, I followed their suggestion of the coin trap, bingo, it was my problem as well. Thanks great help!
SOURCE: fridgidaire affinity gives code e-20 can you help
try RepairClinic.com they have a repair site
SOURCE: e20 error code. what is that?
Read here :
http://www.fixya.com/support/t615626-error_code_e20
Hope this helps. =)
Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Hey friend, thank you for the post!
I see you are getting an 18h code on your front load washer. Normally any error code would have the letter E or F in it. I would suggest that stands for 18 hour delay start cycle, you could do a reset on your washer by disconnecting power to it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this information is helpful. -Matt
