2003 Honda Civic Logo
Yaser Hadi Posted on Dec 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steering lock malfunction
Hello I have a Honda Civic 2003 7th gen manuell. The engine cranks but doesn't start, spark plugs, gas, fuses and battery are ok I noticed that the steering wheel only locks to the left and I was wondering if this could be affecting the engine and stoping it from starting. Excuse my poor english. Thanks
dago88881
Level 2:
Habit-Forming:
Scholar:
  • Expert 132 Answers
  • Posted on Dec 25, 2017
dago88881
Expert
Level 2:
Habit-Forming:
Scholar:
Answers
132
Questions
0
Helped
22372
Points
419
Check cranking compression also is ther gas on the spark plugs after cranking the motor say 20 seconds no gas then suck some gas into a 2 foot peice of vacuum line blow this gas into the manifold throttle(a spoonful) then crank if it starts then maybe bad fuel pump check to see if fuel is at fuel rail when the motor is cranking got gas? got spark ?are plugs blak and sooty ?(repleace) then check compression if its low by 20 to 30 pounds or has nun its jumped time at the timing belt/chain ask about that at auto zone and the ramifications
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on May 31, 2008
SOURCE: 97 honda civic wont start.
If the car has over 100,000 miles on it, you may need to replace the distributer. I don't think the bad gas caused this issue I think it may just be a coincdence. But if you already changed the plugs, wires, distributor cap, and rotor, I would definetly check the distributor.
Anonymous
  • 15 Answers
  • Posted on Dec 20, 2008
SOURCE: Doesn't start - FI warning light & no spark
I have encountered this problem on 3 different occasions. I have had to pull the fuel pump, carefully disassemble the entire thing, using an air hose to clean it out, only to reassemble and reinstall it...tho frustrating and very time consuming, the settlement thats in gas can clog the fuel filter inside the pump causing a major inconvenience. Also when you dismantle your bike take an extra hour and some carburator cleaner and clean out your throttle bodies and fuel lines...90% of FI problems are fuel pump related
Anonymous
  • 137 Answers
  • Posted on Jan 30, 2009
SOURCE: honda cbr 900 94 wont start
hi m8,, having a head ache i see,, my m8 had one of these,, still has,, and had the same problem, i see u have checked a few things there ,,and convinced they are ok,, then ,check u dont have an air leak in the air box,, and all clips are secure, and that u havent creased the fuel or vacume pipes under the tank,,if all is ok, behind the rear side panel is the aluminium lookin cdi box ,or ignitor, with about 5 or 6 wires connected to it,, u need to get this tested ,, or borrow 1 and try it,, there about 130 quid new, so test it 1st,, this does play up,, and 1 min it runs great,, next day 2 miles up the road itl stutter ,,or stop,, any probs m8,, shout and i will anserw,,cheers
Anonymous
  • 39 Answers
SOURCE: hello, my steering wheel is
All you need to do is turn your steering wheel to the left all the way till it stops then put your key in while still holding the steering wheel to the left, turn the key to the on position this should release your steering wheel!
Anonymous
  • 12 Answers
  • Posted on Mar 21, 2009
SOURCE: 1974 honda cb550 will not run?
• The first thing to do with ANY engine that has sat for any longer than a couple of months is to dump ALL the fuel in the tank and carb(s). ALL OF IT !! You'll want to refill with some high priced fuel that has fuel system cleaners (Like Chevron with Techron) not becasue you need high-test fuel, but because you need the cleaners. It's ether that or disassemble the carbs and clean out jets you can't find much less see. Your choice. The carb kits alone will cost you about $50 so a tank of high-test is looking pretty good, huh?
• Now the fact that you tried to crank the engine with old fuel has fouled the sparkplugs. All of them. Go buy all new sparkplugs.
1helpful
2answers
Why doesn't this 2000 Honda civic lx turn over when everything else works inside the car?
Honda Civic Coupe Questions - car will not start. battery ok ...
www.cargurus.com > Questions > Honda > Civic Coupe
CarGurusJul 9, 2008 - Get someone to turn it over and see if it is getting spark. ... i have the same issue with my 1993 civic lx it has a 1.5 sohc non-vtec i changed ... comes wen the 2nd click of the main relay it doesn't occurs until after few minutes, few .... My 2000 Honda Civic Ex Vtec will not start, has a new tps, new throttle body, ...
Part 1 -How to Troubleshoot a No Start (1.6L Honda Civic)
troubleshootmyvehicle.com > Honda > 1.6L
Dec 31, 2012 - Difference Between a No Start and a No Crank Condition. ... can cause your 1.6L Honda Civic (Civic del Sol) to Crank but Not Start. ... In other words, the engine doesn't turn over at all. ... 1995, 1996, 1997, 1998, 1999, 2000.
98 Honda civic won't crank (PushStart) - YouTube
? 4:11
https://www.youtube.com/watch?v=X5W7OqjKB8I
Oct 21, 2013 - Uploaded by SkzDaniel
Honda Civic won't start or crank with the clutch but goes on when you push start it. ... 2000 Honda Civic LX with new battery and starter. Still will ...
? 6:34
https://www.youtube.com/watch?v=p7KAO__nM1s
Aug 21, 2013 - Uploaded by Robert SnyperMD
2000 Honda Civic LX with new battery and starter. Still will not start. ... Crank, No Start Diagnosis Honda Coil test. - Duration: 11:17. by ...
2answers
97 honda civic wont start,got fuel,spark,compresion,new timing belt,its in time,new spark plugs,new distributor cap,new crankshaft position scensor
I would suggest to get a propane torch and turn on with out lighting it (flame less) Place in intake port to manifold crank and see if starts. this will let you know if injectors are cycling or not. This engine has Three sensors that keep the engine running crank,TDC,cam. The TDC and CAM are in the distributor and crank is behind timing belt cover.
Hello I have a Honda Civic 2003 7th gen manuell. The engine cranks but doesn't start, spark plugs, gas, fuses and battery are ok I noticed that the steering wheel only locks to the left and I was wondering...
no start, cranks ok/
so check for spark, got spark too all 4 cylinders.
you know how to do that, its easy.
the cars ECU brain cuts fuel anytime there is no spark
and honda's have complex ignitions. some have 3 sensors. for spark.
2answers
I have a 2003 civic Honda .engine cranking but wont start.Fuel and Ignition were check already no problem was found. Is it maybe because I have change the original alarm of my car to a new alarm? Do I need...
I would check your firing order, and all the stuff with the distributor, no loose connections and stuff, check the condition of all your plugs, make sure they are gapped correctly, check everything, maybe your injectors are clogged or broken? (unlikely but still check it out) then at last check for compression. All you need is fuel, spark and compression to fire. Check all cylinders to make sure they are ok on everything.
Get your tools (for removing a spark plug) ready. Try to start the engine, pumping the accelerator a little while you crank. Take a spark plug out. Is the spark plug wet with gas (smell fuel)? If so, you are getting fuel. Hook the spark plug you just took out up to the coil, lay it on the engine where it will be grounded to the metal. Get someone to crank the engine, and check for spark at the end of the plug. If there is a good spark, that eliminates another problem (don't crank the engine, or let it run too long with the plug out). If you have spark, and fuel, either the timing is way off (broken, slipped timing belt/chain), or you have no compression (internal engine).
Do you have a "Check Engine" light, or any other warning light on? Recently you make any work there or disconnected the battery? Are you thniking in Theft, Immobilizer or Passlock security alarm? Is this occurrs and the keys isn't work, its need to re-programmed, for this need to visit your Honda dealer.
Keep us updated.
My 1998 honda civic ex. It cranks but Engine does not start . I could not locate the fuel injectors fuse. I openned fuel line and fuel spurt out when it cranking. But I smell no gas at airfilter intake.
How many miles are on it? Have you changed timing belt? Was there any symptoms prior to non starting? Pull a spark plug see if you are getting spark. If not it is probably coilpack on distributor have it tested. Common problem I have had experienced with civics.
1991 Honda Civic Problems car started ok. at stop sign died will not start getting gas turns over fine.seems like no spark
whaddya mean seems like no spark. There's no such thing as "seems like no spark. There either is or isn't and it's easy to tell. remove spark plug lay against good ground and crank. you'll see it for crissse sake.
Not getting gas is a fuel delivery problem, fuse, pump, or relay.
On sunday pray for it. all the other days cuss it out.
1helpful
2answers
89 honda civic swap car wont start
Backfires usually mean it's still out of time, either engine wise, spark wise, or injector wise. I'd pull the cap and inspect the ignition coil if it's that style. Hondas are the easiest cars to get spark plug wires mixed up, even the pros do it every so often. I'd also make sure all your injector connectors aren't swapped around, & definitely check all of your engine grounds. you could also have a bad timing belt tensioner or just be a few teeth off. I always triple check the simple stuff over and over again cuz thats what it usually ends up being... hope this info helps...(subytech1)...
1helpful
Honda civic 96 will not start have check all electrical and pump
check the oil and make sure it's NOT black, Check air filter, oil filter, and gas filter, check engine fuse, see if spark plugs are ok, check starter, check alternator and belt. if problem still persists please contact me at [email protected]
4answers
My 1990 honda civic wont start it is getting spark and also fuel to the injectors
if your car turn over and it sound like it want to start then i think it is your ignition coil so got car scrap yard get another that is your vehicle and put it in.
2helpful
3answers
Starting problem with honda civic
Next things to check are fuel and spark, remove a spark plug and with the wire attached crank the motor, if you see spark in the plug then it's not a spark issue and probably a fuel problem. If there is no spark could be bad plugs or wires, or distrubitor cap. To check fuel remove injector cover and crank motor, if there is no fuel coming out then check fuel filter, fuel pump.
Good Luck
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
