Question about Casio FX9750GII Graphic Calculator
Factoring program - Casio FX9750GII Graphic Calculator
Posted by Patrick Holmes on
k24674
  • Casio Master
  • 8,081 Answers
What is the question. Your calculator FX-9750 GII does not have a Computer Algebra System or CAS, so you cannot factor a polynomial.
If you want you can try to find the zeros of the polynomial function (the values of x when the function crosses the horizontal axis) either by solving P(x)=0 or by graphing y=P(x).
Once you have the approximate roots x_1, x_2, ...,x_n, you can factor out the coefficient of the leading term (the term with the highest power) and write P(x) =a_n *G(x). here a_n is the coefficient of the leading term.
G(x) can then be written as G(x)=(x-x_1)(x-x_2)*(x=x_3)...(x-x_n)
and the original polynomial will be
P(x)=a_n(x-x_1)(x-x_2)*...*(x-x_n)
Note: Here is an example of P(x) and the corresponding G(x)
P(x)=5x^3+7x^2-13x^+29
P(x)=5(x^3+ (7/3)*x^2-(13/5)x+29/5)
G(x)=x^3+ (7/3)*x^2-(13/5)x+29/5
You should keep in mind that the roots are in general complex. Not all polynomials are factorisable in the set of Real numbers.
Posted on Oct 06, 2013
  • k24674 Oct 02, 2014
    G(x)=x^3+ (7/3)*x^2-(13/5)x+29/5 should read G(x)=x^3+ (7/15)*x^2-(13/5)x+29/5
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Jul 05, 2015 | Casio FX-9750GII Graphing Calculator
SigmaStat two-way repeated measurement ANOVA: error message: You have more than one measurement for a subject within a cell! I checked everything and the data are organized as usual (one subject column,...
I just had this problem. I had factor A as ***, factor B as age, and I was trying to look at my RM data. What I needed to do was separate it out, so that I was looking at factor A as ***, factor B as "session"- my repeated measure. Then I did a separate analysis with factor A as age, factor B as session.
Sep 07, 2011 | Systat SigmaPlot 9.0 (000053608314) for PC
I don't have a mechanical problem with the calculator, but I have a question. Will my Casio factor quadratic trinomials?
Natively, the calculator cannot factor polynomials because it does not have a Computer Algebra System or (CAS). You can however find the roots of the polynomial equation P(x)=0 and factor approximately.
On the Internet, there is a program which you can download and transfer to your calculator. Here is the link (the page is in French).
Dec 09, 2010 | Casio FX-9750GPlus Calculator
I am trying to find out how to factor a number with the T-83 Plus calculator.
Here is a link to Ticalc.org where you can find programs that do prime factorization. You should read the description of each program to find out if it answers your questions.
Using a program from Ticalc.org is under your entire responsibility.
Sep 10, 2010 | Texas Instruments TI-84 Plus Silver...
How do you get a factoring program onto this calculator, that could factor 3 terms? Like X^2 2X - 3 = (X - 1) (X 3)
There are several factoring programs available at
http://www.ticalc.org/pub/83plus/basic/math/algebra/
Aug 19, 2010 | Texas Instruments TI-84 Plus Silver...
Prime factorization
Aug 06, 2010 | Texas Instruments TI-84 Plus Calculator
TI-84 Plus Calculator Factoring Program
There 4 or 5 programs for the TI83/4Plus family of calculators available at ticlac.org. Scroll down the page to find them. Download them and transfert to your calculator using TIConnectivity software.
Hope it helps.
Thank you for using fixYa and for rating the solution.
Dec 02, 2009 | Texas Instruments TI-84 Plus Calculator
Write a c program to find the largest prime factor of a number
#include<stdio.h>
#include<conio.h>
void main()
int num,i=1,j,k;
clrscr();
printf("\nEnter a number:");
scanf("%d",&num);
while(i<=num)
k=0;
if(num%i==0)
j=1;
while(j<=i)
if(i%j==0)
k++; j++;
if(k==2)
printf("\n%d is a prime factor",i);
i++;
getch();
May 16, 2009 | Computers & Internet
Can you Factor on a TI-84? IF not, does the TI-89?
Well, to answer part of your question, yes... the TI-89 does factor like this. it is inputted like this:
factor(6*x^2+11*x+4,x)
Check the catalog in the TI-84 (which is 2nd-zero) and look under F for factor()
Jan 12, 2009 | Texas Instruments TI-89 Calculator
Factoring
x^2+5x+7 won't factor any more.. if you're trying to solve it, do:
solve(x^2+5x+7=0,x)
May 15, 2008 | Texas Instruments TI-89 Calculator
Casio FX9750GII Graphic Calculator Logo
167 people viewed this question
Top Casio Office Equipment & Supplies Experts
Ekse
Colin Stickland
Colin Stickland
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
