So, I have this Chinese android phone - MBO E7 (image below), and when I am trying to turn it on it freezes on Android screen. Supposedly I need to reset or flash it, but I don't how to reset it with external buttons (it only has Power and Volume buttons). I need to know how to flash and reset it, and what is best .rom for this phone? Please help
If you can access the settings you can reset it by using this guide: http://www.wikihow.com/Reset-Your-Android-Phone
Testimonial: "Thanks for answer. Phone wont turn on... That's why I need external key shortcut to access phone."
update: I managed to turn phone on, but now I need .rom for it. Can some upload it?..
can you not access settings to perform a factory reset? ive just had a look online for a rom but cant find anything
there is no factory reset :( kernel version 2.6.35.7 and software E7.JLF.A2.MULTI.0417.V3.07 - can I put some other rom in this phone? :)
Can you see the home screen? if so go to Settings - Privacy - Factory reset
if you can't access the home screen then you will need a new rom
it did not help :((
use Power+volume up....cell must be Off At that Time..It Will Take you to Recovery..Hope It will Help
my MBO Z4 Shows exclamation mark on a triangle and a phone down when I hold vol down and power.what can I do to get into wipe
SOURCE: g1 boot up error
when i turn my phone on it wont go to the android area. instead it shows a picture of my phone with a exclamation inside a triangle... ive tried to reset it and it wont go past this.
SOURCE: I have a LG GT540
hey man ok so go ahead and pull out the battery ok re install batter and before you turn on again hold the volume down key and then turn on the phone while holding down the vol down button when you get to the system recovery screen it will say 2e recovery just reboot systom from there and you should be all set
SOURCE: lg android lock how to
I am really sorry for the inconvenience, but don't worry I will definitely help you on how to reset your LG Android.
Turn off the phone and then press and hold the power, volume down and
home buttons. Wait till you see the droid with the progress bar under it
then release the buttons.
Please let me know whether you were able to reset it.
Thanks.
SOURCE: How do I install adobe
Try skyfire, this is a third party browser that supports flash.
Or root the phone and then install the Flash app.
Instructions can be found here.
SOURCE: HI my HTC desire keeps
its the fault in the restart integrated circuit its gets stuck when it gets heated,better replace it
If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below:
