Konica Minolta magicolor  2490MF Laser Printer Logo
Hans Kuchwalek Posted on Oct 06, 2013
Konica 2490MF After fixing the "Registration
Konica 2490MF After fixing the "Registration solenoid SD2 fault" (the printer works fine now), I get the error message "scanner unit open, close scan unit...", but it is closed... How will the mashine know it is open? Where is the sensor? an what kind? I found so far a "Reed-Switch" on top near the original glas , near keyboard-error sign, the magnetic is in the cover. This works fine as I knew. Any Idea how to fix? I have had the Autofeed cover off the main-unit to repair the SD2. After put it all together, I get that error.
  • 2 more comments
  • Hans Kuchwalek Oct 07, 2013
    in the meantime I found it myself. The Sensor is in the left corner of the scanner unit, it seemed to be a reed switch. Because I took the unit down from the main machine, I did not put it back in the correct way. The left corner could not close near enough.
    I made three pictures of this situation.
    Hans
    http://www.arcor.de/palb/einladung_accep...
    The first link has been cut off, the second should work
    Hans Kuchwalek
    in the
    Hans
1 Related Answer
Anonymous
  • 70 Answers
  • Posted on Sep 02, 2008
SOURCE: The Error says "Cover Open Front" but it is not open
Most printers have a plastic pin on all of the covers that pushes a switch when it is closed. This then sends a signal to the printer telling it "I'm closed".
Probably the pin is broken off (quite by accident I'm sure). A solution is to push a piece of paper in the hole where the pin is, closing the switch, to fool the printer into thinking that the cover is closed. You can try this by pushing a pen point into the hole to see if the message goes out. (Don't forget to remove the paper when you open the cover. The switch is there to keep things out of the mechanism while it is running. May not hurt you but will damage the printer mechanics irreparably.)
Anything else is an error with the printer software and processor and can't be fixed easily.
I neede the driver for Konica Minolta MAgicolor 2490MF,
1st You download Printer Driver. Free Konica Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
1helpful
Trying to set printer up with lap top
Hi lewis, you can check konica minolta's website and check the downloads section for your camera model's software and driver. At times, they also sell it on the web via the manufacturer's website if you want a CD copy. Check with Konica themselves so you get the genuine copy.
1helpful
KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
7helpful
2answers
Konica Minolta 2490MF - Paper size error
Need to set A4 size default on the printer driver itself.
Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences /
Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set.
Click apply.
should be o.k.
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
