If the filter is clogged, and the machine is'nt totally empty of water, the door will not let open. I suggest you should check the filter behind the small square "door", down on the left side of the front, and clean the filter well if there's something there:)
A electrical short circuit keeps blowing the fuse . Looking at a wiring diagram an using a DVOM - digital volt ohmmeter to test the electrical circuits is how to find the problem . With not having the vehicle here to test i would only be guessing as to what the problem is . Plus you need to train to learn how to fix these type problems . https://www.youtube.com/watch?v=SO-eKuhCOqc
You need to look an see what else that fuse powers ,fuse's sometimes power other thing's besides what the fuse is called .Power locks fuse # 32 20 amp. Does the car have keyless entry ?
xTooltipElement
Service Information
1999 Chevrolet Monte Carlo ' Monte Carlo, Lumina (VIN W) Service Manual ' Body and Accessories ' Doors ' Description and Operation ' Document ID: 292071
Power Door Locks Circuit Description
Models Without Keyless Entry
When either door lock switch is pressed in the power door locks system, all doors lock or unlock in unison. Each lock can also be operated manually from the locking knob.
The locks are operated by reversible actuators that receive voltage from the door lock relay assembly's two built-in relays. The relays energize the actuators by applying voltage to one of the terminals and ground to the other terminal. In order to reverse the actuators, the polarity to the terminals is reversed.
The door lock switches are usually closed briefly. If the door lock switches are held closed, a circuit breaker in each actuator will open to protect against damage. The circuit breaker resets only after voltage is removed from the actuator.
Lock Operation
Pressing the lock position on either door lock switch sends a voltage signal in CKT 195.
Pressing the lock position turns on the lock relay located inside the door lock relay assembly. The lock relay completes the circuit that supplies voltage to CKT 295. CKT 295 is the voltage feed to the actuators.
At this time, the unlock relay is not energized. When the unlock relay is off, CKT 294 is grounded, which provides a ground path to the door lock actuators.
The entire action described completes the electrical circuit the actuators in each door, thus locking the doors.
When the door lock switch is released, the lock relay contact closes to ground, and the actuators turn off.
Unlock Operation
Pressing the unlock position on either door lock switch sends a voltage signal in CKT 194.
Pressing the unlock position turns on the unlock relay located inside the door lock relay assembly. The unlock relay completes the circuit that supplies voltage to CKT 294. CKT 294 is the voltage feed to the actuators.
At this time, the lock relay is not energized. When the lock relay is off, CKT 295 is grounded, which provides a ground path to the door lock actuator.
The entire action described completes the electrical circuit to the actuators in each door, thus unlocking the doors. The polarity of the voltage to the actuators has reversed, causing the actuators to run in the opposite direction in order to unlock the doors.
Models Equipped With Keyless Entry
All door locks operate the same as vehicle models equipped without keyless entry, except the left front door lock.
Lock Operation
At this time, the lock relay is not energized. When the lock relay is off, CKT 295 is grounded, which provides a ground path to all door lock actuators, except left front door lock actuator.
The left front door actuator is grounded through the Remote Control Door Lock Receiver, RCDLR, CKT 694. The RCDLR has a built-in relay. When the built-in relay is de-energized, the relay provides a path to ground to the left front door actuator.
The entire action described completes the electrical circuit to the actuators in each door, thus locking the doors.
Unlock Operation
Pressing the unlock position on either door lock switch sends a voltage signal in CKT 194. The signal is sent to both the unlock relay located inside the door lock relay and the Remote Control Door Lock Receiver, RCDLR.
Pressing the unlock position turns on the unlock relay, and signals the RCDLR to unlock the left front door. the unlock relay completes the circuit that supplies voltage to CKT 294. CKT 294 is the voltage feed to the actuators, except the left front door lock actuator.
The left front door actuator receives voltage through the Remote Control Door Lock Receiver, RCDLR, CKT 694. the RCDLR has a built-in relay. When the built-in relay is energized, the relay provides a voltage to the left front door actuator. The RCDLR energizes the relay when it receives a voltage in CKT 194.
At this time, the lock relay is not energized. When the lock relay is off, CKT 295 is grounded, which provides a ground path to all door lock actuators.
The left front door actuator is grounded through the Remote Control Door Lock Receiver, RCDLR, CKT 694. The RCDLR has a built-in relay. When the built-in relay is de-energized, the relay provides a path to ground the left front door actuator.
When the door lock switch is released, the unlock relay contact closes to ground, the RCDLR left door unlock control relay contacts close to ground, and the actuators turn off.
Doesn't have any relay's for the door locks . The (GEM) generic electronic module controls the door locks . Your best bet , take it to a qualified repair shop.
The Door Lock Function
When a door lock control switch is moved into the lock position or a door lock cylinder is rotated to the lock position, a ground is provided to the lock circuit input to the generic electronic module (GEM). The GEM then provides 12 volts to one side of the door lock actuators contained in the door latch assembly and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors.
The Door Unlock Function
When a door lock control switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the GEM. The GEM then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch assembly and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which then unlocks the door(s).
Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1300
Power Door Lock Circuit Failure
GEM
Go To Pinpoint Test D .
B1309
Power Door Lock Circuit Short to Ground
GEM
B1310
Power Door Unlock Circuit Failure
GEM
B1341
Power Door Unlock Circuit Short to Ground
GEM
Have a qualified technican diagnose the problem .
Your Focus may be equipped with the autolock feature. Try this:
To deactivate/reactivate the autolock feature using the power door unlock control
You must complete steps 1-7 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control.
The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
2. Place the key in the ignition and cycle the key from the OFF position to the ON position for a total of four times ending in the ON position, do not start the engine.
3. Press the drivers side power door lock switch to lock the doors within 30 seconds.
4. You will hear a single chime when the programming is completed.
5. To activate the feature again, repeat the above steps.
...And from pages 12-13:
To unlock the doors and liftgate: Press and release the UNLOCK button on the key fob once to unlock the driver's door, or twice to unlock all doors and liftgate. The illuminated entry system will also come on. The system may be programmed to unlock all the doors, on the first press, using the following procedure:
1. Close all the doors.
2. Place the key in the ignition and turn the key between the OFF and ON position consecutively for a total of four times ending in the ON position (do not start the engine).
3. Press the driver's side power door lock switch to unlock the doors and within 30 seconds to lock the doors.
4. You will hear a single chime when programming is completed.
Hi, In order to unlock the oven you need to perform the following: Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door. Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls. Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled. Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Thank you for contacting Fixya.com
Set the following conditions:
Ignition off and ignition key out of cylinder.
All doors closed except drivers door.
Drivers door is unlocked.
Insert and remove the key from the ignition switch twice within 5 seconds.
After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode.
1 time for add mode
2 times for rewrite mode
3 times for confirmation mode
5 times for prohibition mode
Remove the ignition key from the key cylinder.
After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode.
In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered.
In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times.
If the prohibition mode or confirmation mode is selected, registration procedure is completed.
If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode.
If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed.
If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
Registering new recognition codes for the add mode or rewrite mode.
Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds.
Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter.
If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters.
If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
