Question about Furniture
Human touch massage chair remote lights blinking on Width and everything quits
2 Related Answers
Azrael SRL
  • 11800 Answers
SOURCE: My EMS 9 massage chair
The massaging is done by small motors with eccentric weights attached to the shafts. Those motors are controlled thru a very simple control board that in your case appears to have failed.
To fix the chair you will have to access the board and find out why it has failed - at least a basic experience in electronics is required, to perform the tests on the relays and triacs used to control the motors. If you don't posses this experience then all you can do is to check that the power cable, the remote cable and the motors cables that plug in the board are firmly inserted - for everything else you will have to call a pro.
Posted on Sep 14, 2011
I would like to buy the remote control to my human touch massage chair HT-135
I would check with these people. I am unsure if this is the remote for your system but it may be.
Human Touch Chair Parts
Sep 10, 2017 | Furniture
Need wiring diagram of chair, schematic of remote and p.s./controller board
i have ALINCO MCR2100 massage chair it operate 15 min and then it cut off and operate after 1 hour when operate it no work
Jun 20, 2011 | Human Touch Ijoy 100 Robotic Massage Chair...
I have a HTT-9CB Massage chair that needs a circuit board, (just stoppped running) blown fuse on circuit boar and what appears to be a resitor is burned. In short does anyone know where I can get a circuit...
Test the resistor for continuity if it has a continuity readind with the power off then it is bad, you can get the replacement parts at radio shack and change the fuse and the resistor out with a soldering gun.
Oct 17, 2009 | Interactive Health Human Touch Black...
After a few minutes, all 3 lights to the left of
This is a problem with the width/kneading cam motor or the portion of the PCB that controls this motor. None are available as separate replacement parts. Human Touch will only sell the entire backrest assembly which costs about $600 plus another $60 for shipping. It can be replaced without tools in less than five minutes.
Jun 04, 2009 | Human Touch HT 7450 Massage Chair
Not getting any power to chair
Make sure there is power at the outlet. Check the fuse panel. If there is still no power then check to make sure there is no GFI (ground fault interupt) switch on the chair itself. The GFI is a 2 button switch that will say "Reset" and "Test"
Nov 30, 2008 | Interactive Health Black Leather Ht 130...
Furniture Logo
671 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
