Mi T M Chore Master Pressure Washer - 5.5 HP Honda OHC Over Head Cam Logo
A
Anonymous Posted on Oct 05, 2013
Clogged orfice on carb. on a 5.5 honda 160 gvc
Honda gcv 135
yes it does but you said it had spark and fuel try squirting some starting fluid in it try to start if start good if starts and stop rebuild carb take to dealer 100.00
Sep 03, 2014 • Garden
Grade of oil for honda gvc powerwasher
30 weight high detergent evry fifty hours due to the fact that it has a plastic camshaft
1helpful
WHERE IS THE EXPANSION VALVE/ORFICE TUBE ON A 1991 HONDA CIVIC
The expansion valve is located after the receiver-dryer, just at the firewall, before the evaporator.
murf427
I have a brand New Black Max with a Honda GVC 160 engine walk behind mower. Gas leaks out of the air breather/carburetor. Will start but I'm not using it with it leaking. It has 5 gaskets and I'm...
Needle seat adjustment is not correct , sounds like to me, but first take your fuel cap off and see if it quit's leaking,a bad cap can cause this it creates a vacumn when shut off and siphons tank dry out the carb
May 16, 2011 • Garden
2helpful
NEED PART NUMBER FOR HONDA DRIVE BELT GVC 160
The drive belt will not be a Honda part but a Husqvarna part. 532408031 You can also get the same belt as an AYP part by dropping the "532" and using 408031. Hope this helps.
Honda, self propelled lawn mover. GVC 160. Used
Could be Flywheel Key, Coil and Do buy a New Spark Plug. Make sure Head bolts are tight.
Jun 26, 2009 • Garden
3helpful
Honda gvc 160 not starting. cleaned the ventui & plug
Check the fuel.
Drain some of the fuel into a white contain...I use a paint can lid. If it yellow to orange in color it's bad. You can pour the fuel into your car to get rid of it. A car has electronics that will compensate for poor fuel quality, small engines don't.
Check spark.
Remove the spark plug and reinstall the wire. Lay plug on the engine block where it can contact it. Pull over the engine. You should see spark. If not change the plug. If still no, I give you further instructions.
1helpful
I cannot get the gas powered honda gvc 160 press wash to start
Pull float bowel and check carb may need to clean it. Drain any water from tank through fuel line.
I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
Nov 13, 2008 • Garden
Top Mi T M Garden Experts
Jay Finke
Jay Finke
john h
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
