Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana bottom freezer: water leaking & ice build-up
We have a Stainless steel refrigerator with the freezer drawer on the bottom, AMANA model #BRD18V1.
Water leaks occasionally onto the floor on the right hand side of the unit and there is significant ice buil-up on the floor of the freezer that we need to manually remove at least once a month.
Any help out there?
Thanks
Charlie
Posted by charlie276 on
richie46
    Top Expert:
  • Amana Master
  • 12,962 Answers
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Posted on Sep 09, 2017
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: Amana ABB2224DES Stainless Steel Bottom Refrigerator is war
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Posted on Sep 03, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Posted on Feb 13, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: NO ICE IN MY BOTTOMFREEZER AMANA REFRIGERATOR
If we both are on the correct subject then it is possible the water control valve on back of refrigerator is not working. If ice tray is dry then fill with water from a cup and let freeze. If the ice maker dumps the ice let me know and we will go from there. Sea Breeze
Posted on Apr 26, 2009
Anonymous
  • 256 Answers
SOURCE: My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Posted on Apr 13, 2010
Testimonial: "Thanks he is on his way!!! Great work!!"
Anonymous
  • 57 Answers
SOURCE: I have an Amana BRD18V1 or V2, bottom freezer.
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Posted on Jul 15, 2010
Ice build up in the bottom of the refrigerator.
some drain line is plugged . our Amana does the same thing and we use a hammer to break the ice out weekly
Mar 12, 2015 | Frigidaire Refrigerators
Ice is forming under the freezer drawer what causes this
Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
Apr 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
Aug 13, 2011 | Amana Refrigerators
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
Apr 26, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Regrigerator isn't cooling - freezer is fine....
Make sure there is not a ice build up in the back wall of the freezer.
If so, you have a defrost issue.
Make sure the freezer fan is blowing.
If so, you have a thermistor issue.
Feb 22, 2009 | Amana ABC2037DTS Stainless Steel Bottom...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
339 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
