Hi, Whenever you assign the same IP to the both the Modem and Router, this sort of this happens. In order to access the Modem, you have to either remove the router OR connect directly to the Modem (ENHWI-2AN3) through a patch of network cable connecting the cable at any of the LAN ports (yellow ones) and LAN card of your PC/Laptop.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
>in order for you not to have more problems at all >first, ask AT&T to set your motorola modem to BRIDGED MODE first >then, connect your Netgear router to the modem >connect the desktop computer to the router and check you connection >after you got the desktop computer connected to the internet >try to establish connection to your wireless network using your laptops (Laptops cannot connect to Motorola modem since it doesn't have wireless capability like routers)
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :- wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
If you connect the computer directly to the modem, does it work? If that works then the modem is working. Now connect the computer to the router and the modem to the router. You will need to open the set up page of the router to check the settings of the router. You can set up the router without the CD also. It is very easy. Click Here for step by step instructions about how to set up the router
modem to router to wireless router if you want (plug the wireless from a regular port to a regular port in first router, do not use the uplink port. from either router - run to any computer you want.
Get Network Magic to help you setup and manage your network.
Free to download and evaluate period ... read details while there ... It is a great manager program
