Black space on the right side of the monitor
NO PC told ,NOR OS NOR..
no connections told VGA or DVI,????????????
vga must be hand set in OSD to get
THE black space right side GONE AND correct?
one just moveS the oSD BUTTON to vga horz position and move it to the right cured.
HORZ, UP /DOWN VERT UP/DOWN GAIN OR HORZ AND VERT POSITION, 4 SETTINGS IN FACT
GAIN SPREADS THE RASTER , POSITION ONLY SHIFTS IT.
DVI is automatic digital correction. so must be VGA FAILING.I guess set wrong. VGA is pure RGB analog signals.
SOME MONITORS TRY TO GET AUTO VGA SCALED RIGHT BUT FAIL. SO WE DO IT BY HAND. VIA OSD.
VGA SCALERS LOVE TO FAIL FOR DECADES AND IS NORMAL.
THE MANUAL I READ IS VGA /DVI
AND WE ALL KNOW SOME ARE VGA ONLY. SUB MODEL CODES ?
GUESS YOU MEANT RIGHT SIDE IS BLACK VERTICAL BAR.
NOT THE CLASSIC CASE BELOW AS MOST ARE NOW CCFL DEAD.
not one word on how big is this spot
1 pixle
1/2 of he screen, "
CCFL lamps burned out on all these now or just 1/2 of them.
not posting photo of failing screens is no good here.
i can name 25 things ugly screens can and size matters
lines, impact damage, CCLF dead or .1/2 of them.
the monitor can be tested on a 2nd good PC, if fails there the monitor is bad.
2004 made and record life span of 13 long years amazing
most burned out in 2009 , used for 5 years 10 hours eachday
a good run it was.
shine a flashlight at black screen PC running,
and see data there good, the CCFL are toasted.
unit turns on.can see temp depth numbers. can work all the switches, background lighten screen but still very dark
