Tub was working just fine for about 10 minutes. Then the jets just shut off. still getting power. Cant get jets to come back on?
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
SOURCE: kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
SOURCE: no whirlpool jets
It sounds like the motor needs to be lubricated or there is debris keeping the impeller from turning without the help of a littl force. I would have a professional that deals with whirlpool tubs come and lube the motor.
SOURCE: whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
SOURCE: four inch crack in the bottom of aquaglass tub styren
CONTACT COMPANY THAT FIX CRACKED CAR WINDSCRENS, THEY CAN PUMP A POXY RESIN INTO CRACK .
