Question about Electrical Supplies
How to install a trimatron toggle dimmer - Electrical Supplies
Posted by Thomas on
mikadot
  • 2,113 Answers
The ground wire goes to the ground. The live goes to the black. In the electrical business red usually signifies a switched wire (or a second circuit). So therefore the red goes to the load (light fixture etc.).
Posted on Nov 21, 2013
4 Related Answers
Anonymous
SOURCE: Trying to install trimatron 120vac push dimmer
Called the guys at Home Depot and they helped me over the phone.
thanks
Posted on Mar 22, 2009
Anonymous
  • 1605 Answers
SOURCE: i have the Trimatron Dimmer switch to install,
one black from the dimmer to black. the other black from the dimmer connected to red. the green connected to the bare wire.
Posted on Mar 27, 2009
Anonymous
  • 66 Answers
SOURCE: On/off works but dimmers do not. leviton toggle
If each pendant has an individual transformer that is about the size of a hotwheel then you need a dimmer specifically for ELECTRONIC LOW VOLTAGE. A lot of electricians don't know that the different types of lights require different dimmers. Most store bought dimmers are for incandescent lights only, and some nicer dimmers like the Lutron Maestro's are rated for incandescent or MAGNETIC Low Voltage which require a different Sin wave interuption. I don't know that leviton makes a dimmer in that style for Electronic Low Voltage. You could install a Lutron DVELV300P-Wh, but that is a Decora opening. http://www.lutron.com/CMS400/WorkArea/downloadasset.aspx?id=25437
Here is a link to explain the difference in how the dimmer needs to work. Good luck!
Posted on Mar 04, 2010
Testimonial: "Excellent answer! As Lutron is not available in my small town (on an island in Southeast Alaska) I will likely be ordering a dimmer online. Thanks!"
BoomerP
  • 107 Answers
SOURCE: I am replacing a two
The best thing you can do in that situation is match the wire colors of the dimmer to the colors of the screw terminals on the switch you removed. Unfortunately, its too late for that - so here's my best guess: One of the black wires in the box will be coming from the same romex cable as the red wire. Take THAT black box wire and connect it to one of the red wires on the dimmer. Take the red box wire and connect it to the remaining red wire on the dimmer. Connect the black dimmer wire to the remaining black wire in the box. The two white connectors in the box get tied together - they don't get tied to the dimmer. And the ground (green) wire on the dimmer just connects to the bare ground connection in the box itself - or to the metal backbox - or cut it off and don't use it.
Posted on Aug 25, 2011
TWO BLACK WIRE COMING FROM THE WALL ONLY DIMMER SWITCH LIGHT WONT GO UP AND DOWN
You are trying to connect a three-way dimmer in place of a single pole switch
Jul 02, 2013 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
Trimatron 3 way push on off dimmer switch
That means you have taken a 3 way switch off and you need to purchase a 3 way dimmer.
Jun 22, 2013 | Electrical Supplies
Dimmer flickers
most likely the type of lamps/bulbs you have are not compatible with the dimmers.
Mar 21, 2013 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I have to replace trimatron push on/off Dimmer. the old that needs replacement has 2 "travelers" while the new one same manufacturere has back red and green. How do I connect to existing...
If the new one has black, red and green, then it must not be a 3-way. Green is universally the ground and the black and green would be the in and the out (either way) on a 2-way switch. You are one lead short! Good luck, Al K
Jun 01, 2011 | Rotary Leviton 836-6683I Trimatron Deluxe...
Installed a dimmer switch to a light. Put power back on and the light came on. Wouldn't dim however and when I turned it off it would not come back on. fuse is OK
Is the dimmer rating higher than the load? Are you trying to dim fluorescent lamps? A flourescent requires special dimmer switch.
If you over loaded or mis-wired a transistor or wire wound dimmer, you may have damaged it.
Is this a three way light circuit?
May 30, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
The house has a red and black wire the trimatron has2 black one green am i missing a wire or does one black not get hooked up?
Rotary dimmers have 2 black wires, and the color-code tells electrician that both blacks are interchangeable.
This means that dimmer is for single pole only. That dimmer will not work for 3-way switching where more than 1 'switch' controls same Load (light fan motor)
Connect either black dimmer wire to the red, and connect other black dimmer wire to the black.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
I have a black wire a white wire and a ground
The red wire is your chase wire and needs to go all the way to the other switch
Mar 07, 2010 | Leviton Rotary Dimmer 6683-i Ivory 3-way...
I have the Trimatron Dimmer switch to install,
Mar 20, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Install a single pole light dimmer
House wires are for a 3 way switch, you will need a different switch
Jan 31, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Electrical Supplies Logo
136 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
