Question about Visioneer Office Equipment & Supplies
Visioneer 8700 one touch image transfer pending
4 Related Answers
rootmusic
SOURCE: Troubleshooting Visioneer One Touch 7100 USB
Okay , You can scan once. Then close the scanner monitor controls. Then START-Programs-Paperport-Scanner Monitor. This reopens scanner Monitor for next scan. You may also have to START-Run- then type in %Temp%. Go to the One Touch folder to get your pics and delete all files before you scan another pic.
Posted on Dec 03, 2008
Anonymous
  • 124 Answers
SOURCE: i have lost the CD to my Visioneer one touch 8700 usb
http://support.visioneer.com/products/8700/downloads.asp
Posted on Feb 17, 2009
thunderbo611
Josh Levin
  • 75 Answers
SOURCE: Visioneer 8700 flatbed scanner stuck in Preview
restore to factory settings
Posted on Jan 26, 2010
Anonymous
  • 3513 Answers
SOURCE: my visioneer one touch 8700 scanner shows up not
Thanks for writing to Fixya.com .
This is a very common problem seen due to MacAfee antivirus or any other antivirus installed on your system. Might sound strange but most of these antivirus eliminates script reading due to which the scanner does not work. Either disable it temporarily while using the scanner or you might want to get rid of MacAfee.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Mar 27, 2010
2answers
I had a new install of windows xp (with service pack 3)on my computer and am now trying to install my visioneer one touch 8700 scanner. Is there a problem with the driver and the xp service pack 2? How can...
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
2answers
My visioneer one touch 8700 scanner shows up not
Hi Margaret,
I think are you using windows Vista and Visioneer one touch 8700 won’t work with that but this scanner work with Windows XP with SP 1 / 2000 Pro / Me / 98SE
And Thanks.
I lost my scanner icon from taskbar scanner will not work properl
Right click on the taskbar go to properties then click on customize button and select the appropriate icon u want.
2answers
I have lost the CD to my Visioneer one touch 8700 usb
this is the site where you can download your driver. just follow the instructions:
3helpful
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
One touch 8700 scanner
Dear Donna,
please download the latest driver for your 8700 Scanner for XP ,from this site:
http://www.driver100.com/driver/128/2222/Visioneer_8700_Scanner_USB.html
i'm 100% sure that your scanner will work with XP now.
Cheerup And Be Happy Always
Top Visioneer Office Equipment & Supplies Experts
Ekse
scramblepad
scramblepad
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
