Question about Philips Audio Players & Recorders
Will not power on. The red standby light stays lit. The green light shows up for 2 seconds only when first plugged in and then goes back to red.
Posted by Dame on
avsystemparts.com
    New Friend:
  • 95 Answers
Solutions:
Check and Try
1. Pull out the flex cable attached power supply to AMP PCB. Check power ON of unit.
2. Pull out flex cable of the ROM
Check Power ON of unit
Probably AMP PCB doesn't work
Posted on Oct 06, 2013
3 Related Answers
Anonymous
SOURCE: Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Posted on Dec 22, 2007
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Out of the blue I
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Apr 29, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have a JVC TH-C30 system, the red standby light
When one reports a fuse replacement it would be helpful to know if that was a Hail Mary wild guess or if the fuse was indeed blown.
Posted on May 30, 2011
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
I have a 56" samsung rear projection tv that won't turn on. the red standby light is lit and when i push the power i hear two clicks and the green timer light flashes quickly then the green led stays lit...
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Nov 03, 2009 | Samsung HL-S5679W 56" HDTV
SLIMLINE FAULT PLEASE HELP
try holding the button wen its at standby for about 3 seconds..it should stay green after that..mine did that for a while too but then i held it for a while n it workd
Nov 01, 2008 | Sony PlayStation 2 (PS2) Console
Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Mar 22, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
263 people viewed this question
Top Philips Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
aliasger yq
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
