Question about Danby Furniture
Diy refrigerator repair
We bought the wine cooler from a close friend. She told us that all it needs is R-22. We need to trouble shoot the wine cooler. I hear the fans, the lights are on. Not sure how to check to see if the compressor works or the freon. Just need some basic trouble shooting before calling out a technician for a diagnostic.
Posted by Kari James on
5 Related Answers
Timothy Snead
  • 6 Answers
SOURCE: fan noise
This is most likely due to dirt that has accumulated on the fan itself, making it unbalanced. Otherwise, do a visual inspection of the fan and see if you can see any physical damage. If you can not clean it or otherwise balance the fan back out - then you would need to get a replacement fan. You can call Danby at 800-263-2629 and order the part(s) needed.
Posted on May 27, 2008
Anonymous
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
Anonymous
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
Anonymous
  • 123 Answers
SOURCE: I just bought a wine cooler not sure where to
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Posted on Aug 13, 2009
Anonymous
  • 232 Answers
SOURCE: Koolspace NUVO wine cooler recharge
do you have a recovery machine and gauges you need to tap both sides to check the high to and it needs to be vaccumed down to remove moisture ,find and fix the leak. leaks arnt verry common un less someone broke a line somehow. if the compressor is running it is more likley it has a restriction or bad valve in compressor, hooking to high and low sides will determine which if is less than 5 years old it could be under warrant still most sealed systems have a longer warranty than the rest of it is the evaperator getting cold at all.
Posted on Dec 31, 2009
I have a frigidare #PLKU1267DSO kegbox. the compressor runs and gets hot but the box will not cet cold at all. the coils inside also have rust on them
Your keg box runs very similar to a Wine Cooler. I believe this can help you. The pressure for the freon and the steps for trouble shooting is he same. Give it a try.
Danby Wine Cooler Repair Recharging your wine Cooler with 134a Freon
Feb 19, 2012 | Refrigerators
Wine cooler compressor hums and then nothing.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Danby DWC283BLS Wine Cooler
Fridge will not get cold- i dont hear the compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 06, 2011 | Magic Chef MCWC30MCG Compact Wine Cooler
Cooling problems, wont chill will stay at 72F
Refrigerator
heatman101
Dec 31, 2010 | Avanti Wine Cooler Refrigerator - 28...
Cooler is not cooling and the back of the cooler is hot. product hvts18dtbb
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 08, 2010 | Haier HVTS18DABB Wine Cooler
Not cooling
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 31, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
Not cooling
heatman101
Aug 24, 2010 | Haier BC112G Wine Cooler
Why would my wine cooler only cool to 60 degrees?
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 19, 2010 | Emerson (025806803716) Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
Wine refrigerator is not worjung
IN YOUR USER MANUAL THERE WILL BE A TROUBLE SHOOTING SECTION. CHECK IT OUT AND IF POSSIBLE GET A TECHNICIAN.
Sep 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Furniture Logo
47 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
