Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for  DX SLR Cameras Logo
Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED AF-S DX Zoom Lens for DX SLR Cameras
Clean inside lens fungus
Posted by barid on
Harrie
    Top Expert:
  • Nikon Master
  • 6,746 Answers
If you realy have fungus in your zoom lens, you can't do anything. If it does not show on the pictures, just keep the lens dry. (use silica gel) If you want it it be repaired, it will cost more than an new lens.
Posted on Nov 06, 2013
  • Harrie Apr 15, 2014
    Aceton will defenetaly remove the coating too. The mould is in the coating. When the coating is gone, the lens will never be the same. If you think you can replace one lense element without a colimator you must have good eyes. On the other hand, if the mould is destroying your pictures, what others thing could you do with the lens? I think giving it in repair with Nikon is as expensive as a new lens.
  • Cosku Arsiray
    Cosku Arsiray Dec 02, 2014
    this is totally wrong. if you can disassable lens elements acetone is the only choice to remove fungi and its traces.
Cosku Arsiray
    Novelist:
  • 210 Answers
You need to disasamble the lens. newer and cheaper models can not be parted due to plastic moulding processes. if you can remove glass elements, fungus can be cleaned by pure "acetone" and a good quality micro fiber cloth. do not spill acetone to plastic body parts, you may not recover it. some fungus can left traces on antireflective coating you cant fix that but it has no harm on images.
Posted on Apr 15, 2014
1 Related Answer
Anonymous
  • 45 Answers
SOURCE: clean fungus rear lens
Oh This Could be a problem. But try just wiping it with a lens cleaning kit. If that dosnt work take it to a camera shop and let them work on it.
Posted on Aug 28, 2009
1helpful
How to clean fungi on lens
The success o cleaning fungus off a lens depends on how far the growth has gone.Light fungus on the outside surface off the lens can be removed by wiping a thin smear of Dove cream on the affected surface and then lightly removing using cotton buds. Follow this with a light polish using lens cleaning cloth. Never use cleaning tissue, it will scratch. A useful tip is to wash the lens cloth in hot water and dish washing liquid and rinse and ry before use. Have a spare clean cloth ready.
If the fungus is to heavy to remove you will still get some improvement using this cleaning method. If the fungus is on the inside it is up to you to decide whether to dismntle the lens.
tip
How to avoid fungus on Digital Camera Lens?
The dreaded fungus is something that bothers every photographer. I have suffered from it before, and every coming rain gives me constant worries of possibilities of fungus growing somewhere inside my lenses. I am more vulnerable to fungus than most people because I don't think much about taking out the camera to get some good shots even if it has been raining a bit, and have often got plenty of rain drops on the camera and the lens therefore.
Where does fungus comefrom?
  • Fungus spores are everywhere and germinate under suitable environmental conditions:
  • Relative humidity of at least 70% (more than 3 days)
  • No or little airflow
  • Darkness
  • Nutrients (textile lint, traces of grease, varnish, dust and dirt)
  • Temperatures between 10 and 35°C
How can fungus be avoided?
  1. Silica Gel. This seems to be the easiest and common way to avoid fungus, but I haven't had much success with it either.
  2. . Store the lenses in an airtight container. Again, you may need to put a few Silica Gels in the container. Putting too many of Silica Gel is known to dry out the lubricants in the lens, so you need to use your discretion with quantity of the Silica Gel.
  3. . A popular idea is to install a low wattage tungsten bulb in the closet where you keep the lens. This will keep the place warm and dry, preventing the fungus. This is known to work.
  4. . Store the lens in transparent container. Fungus is known to fear light and love darkness. Also make sure that the lenses are not stored in leather bags, as leather can easily attract fungus.
  5. And finally, of course, the best way to prevent fungus is to get out and shoot more often.
  6. After the work is done, immediately clean the instruments. If possible, you can use a fan or blower to facilitate evaporation of surface moisture.
on Feb 13, 2010 • Cameras
Cant reach the center of the lens for fungus cleaning...
Are there two nested tubes involved? Male to female threading?
Fungus on Rokinon 500mm mirror lens
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, take it to a good camera shop and have a properly trained and equipped professional do the job.
1helpful
What should i do?...my tamron 17-50 began to have a fungus.
Well, that's a great lens and most definitely worth the cleaning/service. I don't know where in the world you are but fungus growing inside a lens is only heard of in high humidity environments and can happen fairly quickly. Are you sure this is a fungus on the inside and not just a clouded smear on the front element? If the lens is having a problem then the camera won't be to far behind. To answer your question more directly "what should I do" my suggestion is to send the lens to a authorized Tamron service/repair center/depot for cleaning. After which get a few of those little moisture absorbing packets and place them in with your photo gear to help reduce the moisture.
I purchased a televue ranger at an estate sale, have since be informed that there is fungus on the lens. When looking at the lens there is a geometric patter around the outer rim, on the inside. How would...
I would contact Televue and see if they can clean the scope. I would NOT disassemble the lens cell, there are two or three lenses on that scope that must be centered and adjusted using an optical bench. DO NOT take them apart unless you know how to collimate the optics.
http://www.televue.com/engine/page.asp?ID=2
1helpful
Clean fungus rear lens
2helpful
Fungus inside lens
if it's mild then it won't have any appreciable effect on your photographs, so leave it until it's worse. The fungus can be slowed or killed by sunlight or by exposing the lens element to ultra violet light.
If it's really bad then you have to decide whether it's worth a professional strip down and clean. You'd have realistic two choices: to remove the fungus and replace all lubricants and canada balsam lens cement with modern antifungal equivalents but leave the damaged lens coatings as they are or to do the same and also have affected lens groups replaced with new ones or have the old ones re-coated. The first option is expensive, the second option is very expensive.
1helpful
2answers
Fungus in the lens
These lenses arn't designed to be taken apart.
A camera specialist may help but they should alwys be kept dry and at room temp never warm and humid. Silicate gel in your storage bag also prevents this from happening.
Good luck
Marc
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
